STD Tuning Engine OM606D35LA
OM606D35LA
OM606D35LA
German Diesel
04-14-2022, 12:30 PM #1
Hi,
My new Projekt is a OM606 with 3.5 Liter for a looong wheelbase G-Wagon (3120mm).
Special billit Pistons and Billit HX35W Turbocharger
[Image: 43316816gd.jpg]
Crankshaft from a OM603.971 S350TD
[Image: 43316817ww.jpg]
Some machanical work on the boring bar, honing maschine, and the milling maschine and by Hand.
[Image: 43316831sc.jpg]
[Image: 43316833uj.jpg]
[Image: 43316837xd.jpg]
89mm Diameter
[Image: 43316838eh.jpg]
[Image: 43316840pb.jpg]
Put the old valve Guides out
[Image: 43316841vi.jpg]
New guides are assembled, Valveseats are cut (0.1mm then it fits)
[Image: 43316843iq.jpg]
[Image: 43316846ug.jpg]
Final assembly with fresh painted parts  Big Grin .
[Image: 43316853rx.jpg]
[Image: 43316854vb.jpg]
[Image: 43316855hd.jpg]
[Image: 43316857nr.jpg]
[Image: 43316861ri.jpg]
[Image: 43399011kj.jpg]
[Image: 43399012zv.jpg]
TDC
[Image: 43399013ez.jpg]
[Image: 43316862yy.jpg]
With the CAD Model of the Cylinderhead Gasket, i am very versatile with compression ratio, to level the mechanical work, mybe for a deep milled cylinderhead.
I can cut the Gasket with many differnt materials, different sizes, with a copper rinf for better sealing to the cylinderhead, or to seal better wet cylinderlinders in the OM606 Big Grin Big Grin Big Grin .
Also this engine gets the 9mm elements for better performance, higher efficiency factor and lower amount of Diesel in a 2.7t G Wagon (empty).
When i had run the Motor, im not sure if i can run it over idle, so i dont did it. Very Powerful!
https://youtu.be/7ao4lryhhgE
https://youtu.be/nZzuiOu2HpU
Best regards, Steffen
German Diesel
Hi,
89mm Diameter
TDC
baldur
Fast
506
04-19-2022, 01:50 PM #2
Nice work. What did you use for pistons and connecting rods? And 9mm elements, custom made?
In those idle videos it sounds and shakes like one cylinder is completely dead.
This post was last modified: 04-19-2022, 01:51 PM by baldur.
Baldur Gislason
baldur
Baldur Gislason
German Diesel
04-19-2022, 10:48 PM #3
Hi,
Pistons are special made from a little company here in Germany.
They made also Pistons for old engines, where no spareparts are aviable.
The connecting Rods are also special made. The manufacter, i dont now at the Moment, i have to Check it. But i have to do some mechanical work on it, bore the piston pin hole, and hone the bin end.
9mm elements are also special made, from a little company in northern Germany. The grind it from my drawing.
Yes it Sounds a little bit so, but each cylinder fires good.
The engine has to Run in the car, there it is bolt down and nothing can fly away and laying on the ground.
I send a Video when it runs in the car, and the whole assembling oil are gut (-:
Best regards Steffen
German Diesel
Hi,
NZScott
HX30W 73/44mm
398
04-24-2022, 12:26 AM #4
Well done. I've always wondered why this combo isn't more popular
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
German Diesel
04-24-2022, 09:13 AM #5
Hello,
thanks!
Hm i think not much People want to spend so much Time and Knowhow in this engine, when it runs also with 3.0liter.
So it is not just to bore the Crankcase to 89mm and everything fits.
The parts for one engine are too expensive, so i have parts for two more engines.
Pistons, Connecting Rods, Crankshafts, Headgaskets and so on.
German Diesel
Hello,
thanks!
Deltaevo
04-29-2022, 04:06 AM #6
Hello,
nice work !
Could you please give me the Adress of the company that made your pistons?
I need forged pistons for a om605 Turbo with some modifications.
Regards
Deltaevo
Hello,
nice work !
Regards
German Diesel
04-29-2022, 02:49 PM #7
Hello,
please write me a PM
German Diesel
Hello,
