STD Tuning Engine om606 pre-boost excessive black smoke
50harleyrider
GTA2359VK
397
06-26-2022, 04:57 PM #1
Is this something I should decrease pre-boost fueling or a rack adjustment?
50harleyrider
baldur
Fast
506
06-28-2022, 04:03 AM #2
How you fix it depends on what kind of pump it is, but essentially you need to reduce fuelling off boost if it's smoking excessively off boost.
Baldur Gislason
baldur
Baldur Gislason
X Double Dot
07-05-2022, 12:11 PM #3
(06-26-2022, 04:57 PM)50harleyrider Is this something I should decrease pre-boost fueling or a rack adjustment?
you could use the fuel limit table to accomplish this if you wanted.  Just keep lowering the allowed fuel in the appropriate cells until the level of smoke is to your liking.
X Double Dot
