STD Tuning Engine Om602982 with inline pump
Mst61
07-20-2022, 09:46 AM #1
Hey ,can you help me i put my om 602.982 engıne inline pump .i put it before ot 12 degree it runs,but no power and last limit 90 km/h .did i do it wrong .inline pump after ot ??
İ will add pic. Can anyone help me.i must use mecheanical pump with it i put the engıne old g mercedes
Mst61
07-21-2022, 12:32 AM #2
I don't think u can use a inline pump in a DI 602 .98X
Unless one u making the mistake of confusing engines...
602.91x 2.5 n/a IDI
602.96x 2.5 T IDI
602.98x 2.9 DI
602.92x 2.9 IDI very rare...
https://en.mercedesclub.cz/engine_detail.php?id=308
Or someone correct me if i'm wrong, as this 602 as many variants including builds under licence.
And as my knowledge goes, if u want to use an inline pump in a .980 u have to go to a huge assle... as it does not have space for the advance mechanism. It need to be cut in the block...
That is the reason why your engine is not reving up....
Anythimg else PM me .
602.91x 2.5 n/a IDI
602.96x 2.5 T IDI
602.98x 2.9 DI
Mst61
07-21-2022, 07:15 AM #3
(07-21-2022, 12:32 AM)barrote I don't think u can use a inline pump in a DI 602 .98X
602.91x 2.5 n/a IDI
602.96x 2.5 T IDI
602.98x 2.9 DI
Thank you for answer .myengıne remove from 1996 mercedes taxi.they used it 1996 -1999.with edc pump.
İput it in g class with inline pump.but it does not wrll .i set before ot .it crank 90 km/
İ set after ot it doesnot crank.
My friend last qustion
İf i found iveco pump can i put it together my removed edc pump.how can i do it like dieselmeken.is it so hard??
Mst61
602.91x 2.5 n/a IDI
602.96x 2.5 T IDI
602.98x 2.9 DI
07-21-2022, 10:18 AM #4
.98X engines are fitted with bosch VE EDC control... that the name of the thing, and they are controlled by a small ECU.
To increase fuel in this system a diferent programing on the ECU is needed ... simple as that...
U can add a mechanichal solution, of course, and that mentioned Iveco pump is one, but its not its not a simple direct fit...
A 5 CYL VE Right turn need to be built from both pumps. Besides swapping parts and assemblig , other small details need to be calibrated by knownelege tunning fellas... its not something u can do in your garage in an afternoon. of course u can try ....
regards
regards
Petar
7.5mm M pump
459
07-24-2022, 06:57 AM #5
I reccomend keeping the original EDC pump and ECU. It's not that hard today, there is a lot more knowledge than 10+ years ago when mechanical was the only way to go.
You need the original ECU, and
1) fitted with CR1 IMMO emulator. All you need is the engine wiring (already on the engine), MAP and TPS sensors.
2)If your donor car is 96 then it's probably pre EIS then it's pretty simple to also fit the IMMO transponder and the IMMO control module and the coil around the ignition switch.
3) If you have a post 97( 97/01 i think ???) car then it has the electronic ignition switch EIS, which is more difficult to retrofit but still doable. You need the EIS switch, the steering lock and that's pretty much it.
4) Baldur's DSL1 standalone ECU.
Petar
07-24-2022, 12:16 PM #6
5) any edc 15/16 from a group vag vehicle Wink
