S202 OM605 build .
S202 OM605 build .
An update.
So this thing arrived .
I'll have to correct the drawings and upload them . A couple of bolts didn't line up .
Got my hands on a 648 oil pump and 18 tooth chain sprockets .
Gonna reduce the speed of the pump .
For the bolt of the girdle plate I'm using Dacia 1.5 dci head bolts . If you get them from Febi they're 12.9 grade .
They are 20 25mm longer that needed . I plan to experiment with torquing values .
In the book it's 55 Nm + 90 degrees . Plan is to sacrifice a bolt and check at what angle it gives .
Remove 40 degrees and torque it to that .
No pictures of that, but the space is already filled in . Machined a piece of 42CrMo4+QT . No heat treat needed .
