STD Maintenance General time for a turbo rebuild?
cell
01-04-2010, 02:51 PM #1
so my turbo makes a noise. above a certain engine rpm and load (ie, above a certain turbo rpm?) the turbo noise changes from a smooth high pitched whine into a shrill skreetch. when cruising at a high rpm in 3rd (but not high enough to cause a shift to 4th) I can toggle this noise on and off by pushing and easing up on the accelerator.
I've been going out of my way to try and avoid the conditions that trigger this noise, but the problem is that over the past year, I feel like its getting very slowly easier to trigger the noise. not good.
also, I installed an EGT thermocouple in the exhaust manifold over the christmas break, and while I had the intake apart I check the compressor turbine for side play, and its got some. also not good.
the cost of the rebuild kit is $ I'd rather spend towards a VNT, but realistically that could be 6 months away from happening, so I'm thinking I should probably rebuild the turbo to avoid ruining the entire engine.
can I fix this with a turbo rebuild? or is it already too far gone?
cell
01-04-2010, 03:25 PM #2
Why rebuild when a good used one is much cheaper? You sure its even the turbo and not a boost or exhaust leak? Look for oil streaks on the intake side and soot streaks on the exhaust side.
cell
01-04-2010, 04:24 PM #3
(01-04-2010, 03:25 PM)ForcedInduction Why rebuild when a good used one is much cheaper? You sure its even the turbo and not a boost or exhaust leak? Look for oil streaks on the intake side and soot streaks on the exhaust side.
ahh, I didn't realize a used one would be cheaper than rebuilding. I guess the problem would be knowing the good used ones from the bad. I guess you'd look at the odometer and check the side-play?
what do you feel is a reasonable price for a good used T3?
cell
01-04-2010, 04:41 PM #4
$30-100 is the average price, it strongly depends on who/where you buy it from.
All are going to have some oil in the compressor since the CCV system puts a bunch of oil through the intake. Some side-side play is normal, as long as nothing rubs. In-out is what matters, if you can feel it move at all, its worn out.
biotour
01-16-2010, 10:04 PM #5
Where might one find good used turbos in the Denver area? Mine had lots of play so I took it apart and found worn bearings. I have been thinking about doing a rebuild but am not confident it will be in balance because i've read that with a new thrust bearing it still has to be rebalanced. This is how mine looked before disassembly.. http://www.youtube.com/watch?v=91hU5h-cuZc
Ive been to 4 or 5 junkyards and have only seen 2 617's with turbos. I pulled one but it had in-out play. Thinking about checking the other one tomorrow.. any ideas on good yards with more selection?
This post was last modified: 01-16-2010, 10:58 PM by biotour.
biotour
01-16-2010, 11:49 PM #6
check at upullnpay they have a Denver and Aroura location and have and automobile inventory on line!
http://www.upullandpay.com/
the denver location has at least one in stock
I bought my kkk k26 for my 83 300d at pullnsave it is a direct replacement for the garret t3 and spools earlier it cam on 83-85 300d 300sd
http://pullnsave.com/ it kind of hit or miss out there also they are in Aroura
http://www.youtube.com/watch?v=sqdexqX0bhM
I may also have a t3 up at my shop in Berthoud it worked but I don't remember much about it came off 1st weak I owned the car in favor of the k26
also if you need any other engine parts I have three engines torn down in my shop I might have a k26 but it was on an engine that was run out of oil
This post was last modified: 01-16-2010, 11:56 PM by willbhere4u.
01-17-2010, 06:33 AM #7
There is also Colorado Auto and Parts.
turbodanjr
05-16-2012, 02:01 PM #8
Call DONS TURBO SERVICE 541 643 0724 CHEAP PROFESSIONAL RE BUILDER PRECISION BALANCING INCLUDED
turbodanjr
majesty78
05-17-2012, 01:04 AM #9
Gravedigger ;-)
majesty78
Gravedigger ;-)
