The Flyin Pumpkin!
| Author | Message |
Biohazard
T3/T4 ![]() ![]() ![]() Posts: 125 Joined: Feb 2010 Location: NW Washington |
| 02-17-2010 08:56 PM |
c12h23
Naturally-aspirated ![]() Posts: 14 Joined: Dec 2009 Location: washington |
| 02-17-2010 09:23 PM |
Biohazard
| 02-18-2010 10:42 AM |
dropnosky
Holset ![]() ![]() ![]() ![]() Posts: 600 Joined: Apr 2009 Location: CNY |
| 02-18-2010 10:56 AM |
Holset ![]() ![]() ![]() ![]() Posts: 370 Joined: Feb 2008 Location: |
| 02-18-2010 01:09 PM |
Rudolf_Diesel
Super Genius ![]() ![]() ![]() ![]() ![]() ![]() Posts: 459 Joined: Jun 2009 Location: Southern California |
| 02-18-2010 10:12 PM |
Biohazard
| 02-19-2010 09:40 AM |
Biohazard
| 02-20-2010 06:59 PM |
Rudolf_Diesel
| 02-21-2010 03:51 PM |
Biohazard
| 03-08-2010 10:33 AM |
dropnosky
| 03-08-2010 01:42 PM |
TQ is actual power, HP is just math ![]() ![]() ![]() ![]() ![]() Posts: 2,834 Joined: Feb 2008 Location: Colorado |
| 03-08-2010 03:41 PM |
Biohazard
| 03-09-2010 09:53 AM |
Biohazard
| 03-17-2010 10:22 AM |
Biohazard
| 04-04-2010 12:45 PM |
dropnosky
| 04-04-2010 02:30 PM |
Biohazard
| 04-05-2010 08:45 AM |
Rudolf_Diesel
| 04-05-2010 08:56 AM |
Biohazard
| 04-05-2010 02:26 PM |
Biohazard
| 04-16-2010 05:19 PM |
Tymbrymi
Klatta Klatta ![]() ![]() ![]() Posts: 183 Joined: Mar 2008 Location: Starkville, MS |
| 04-17-2010 04:06 PM |
Biohazard
| 04-18-2010 01:21 PM |
| 04-18-2010 05:20 PM |
Biohazard
| 04-20-2010 10:29 AM |
| 04-20-2010 10:58 AM |
Biohazard
| 05-11-2010 08:59 AM |
ConnClark
K26-2 ![]() Posts: 37 Joined: Mar 2008 Location: |
| 05-26-2010 03:53 PM |
Biohazard
| 06-01-2010 04:03 PM |
Brain Ninja ![]() ![]() ![]() ![]() Posts: 432 Joined: Jun 2010 Location: Riverside, California USA |
| 06-04-2010 11:49 PM |
Biohazard
| 06-07-2010 08:50 AM |
| 06-09-2010 09:19 PM |
Biohazard
| 06-09-2010 10:28 PM |
| 06-09-2010 10:32 PM |
Biohazard
| 06-09-2010 10:59 PM |
Biohazard
| 06-14-2010 11:21 AM |
| 06-14-2010 01:44 PM |
bitbanger ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 1,666 Joined: Dec 2008 Location: Atlanta GA |
| 06-14-2010 02:00 PM |
Biohazard
| 06-14-2010 04:40 PM |
| 06-14-2010 06:26 PM |
rajay FB 40 ![]() ![]() ![]() ![]() ![]() Posts: 824 Joined: Apr 2009 Location: Here |
| 06-14-2010 07:20 PM |
| 06-14-2010 08:36 PM |
| 06-15-2010 01:24 AM |
Biohazard
| 06-15-2010 09:50 AM |
| 06-15-2010 11:23 AM |
| 06-15-2010 01:14 PM |
Biohazard
| 07-25-2010 08:46 PM |
| 07-26-2010 12:32 PM |
Biohazard
| 07-26-2010 01:33 PM |
mike-81-240d
Non turbo for now... ![]()
Posts: 15 Joined: Sep 2009 Location: Kirkland WA |
| 07-26-2010 02:17 PM |
| 07-26-2010 02:40 PM |
« Next Oldest | Next Newest »
Search
Member List
Calendar
Help
It had 185k on it when I got it, with 60k on rebuilt trans & cyl head. She's almost to 229k now and running strong. I cut the front springs 2 coils and the rears a coil and a half shortly after getting it. It was sitting in typical W126 fashion with the nose way up. The wheels are "Rage" brand 16x7 with unknown ET; they really have no markings. Front tires are Dunlop Signature 205/55r16, rears are Yoko somethin 225/65R16. The wheels were on the car when I got it a couple years ago. They're still round and hold the tires up so I'm going to stick with'em for a while. I added the taller rear tires for better highway cruising speed and milage. A 22 gallon propane tank (yes, it's effin huge!
) was mounted into the trunk last summer. The propane is boost activated at 4psi and is set up on vapor-draw just before the turbo. I dyno'd the car before gauges, but after putting in propane. With the propane, it made 105 rwhp (94 rwhp w/o?) on B20. I'll edit in torque readings & dyno info tomorrow... My normal driving is about 40/60 city and highway; milage went from average of about 22 before propane to average of about 25-26 with propane for the whole tank. Best highway-only milage was 33mpg at steadyish cruising at 70mph. With the tall tires in the rear, 70mph is just under 3k rpm. I drive to Bonneville Salt Flats for Speed Week (coming up on 4th year in a row!) with my Dad, so the tall tires are a must. It's a bit sluggish off the line, but once the propane kicks in it's all good. My brother got me a Monstercraftman PCV kit for Christmas, so that got put on in Jan. Also put in his EGR delete kit as well. I built a 2.5in cold air intake and put that on at the same time. I still need to build a heat shield, but at least the filter gets some cold air being right at the air snorkel. Finally added a boost and EGT gauge to the car. Built a gauge housing for it and got it mounted to the dash. Still pushing stock boost and running stock exhaust for now. Well, I cut out the twin resonators, but otherwise it's stock. My brother and I just put in new Monarch nozzles recently. Seems to be running a bit smoother now. I knew the injectors were replaced along with the cylinder head etc. I just didn't know if they were used, rebuilds, or ???. I've got other bits & fun stuff in the works, but that's about it for now. Sorry for the crappy cellphone pic, I'll see about better pictures this weekend.
![[Image: Dieselfuelforlife.gif]](http://members.cox.net/lnewcomb99/Pics/Dieselfuelforlife.gif)
I'll see about getting a pic in a day or two, I want to see if it changes color more.
