OM Exhaust Manifold Thread - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: OM Exhaust Manifold Thread (/showthread.php?tid=1694) |
RE: OM Exhaust Manifold Thread - lpumb3 - 01-18-2013 has any one attempted to use the egr port with a small vband External wastegate and a non IWG T3 of some sort ? this would ba on the EGR turbo manifolds. RE: OM Exhaust Manifold Thread - Simpler=Better - 01-18-2013 Not that I know of, but it sounds like a good use for the EGR tube RE: OM Exhaust Manifold Thread - F.R.A.S - 01-13-2014 Here is a custom om605 exhaust manifold on the way to completion courtesy of F-tune Performance in Sweden. RE: OM Exhaust Manifold Thread - ben2go - 01-13-2014 (01-13-2014, 03:26 AM)F.R.A.S Here is a custom om605 exhaust manifold on the way to completion courtesy of F-tune Performance in Sweden. Is that titanium?Looks really good. RE: OM Exhaust Manifold Thread - MFSuper90 - 01-13-2014 Beautiful exhaust manifold work. Why put the charger so low? Would it fit there if all factory accessories were there? (I don't own a 605, I'm just curious) RE: OM Exhaust Manifold Thread - F.R.A.S - 01-14-2014 Thanks! No it's normal mild steel (I think that's what it's called in English) (01-13-2014, 08:46 PM)ben2go Is that titanium?Looks really good. Thanks! The turbocharger are in the stock alternator position =) It's that low because it's closer to cold air and therefore more efficient. It's also closer to the intercooler and will therefore make less lag. To mount the turbo upwards are a solution you only do if there are no other way to fabricate. (01-13-2014, 10:31 PM)MFSuper90 Beautiful exhaust manifold work. Why put the charger so low? Would it fit there if all factory accessories were there? (I don't own a 605, I'm just curious) RE: OM Exhaust Manifold Thread - F.R.A.S - 05-16-2014 Hi guys, here is how an exhaust manifold comes together @ F-tune Performance in Sweden. This is a mild steel manifold for a om606 in a w124 chassis. Collector made Pipes spot welded Port filing Smooth transition More filing Has to be smooth Close up of the wastegate tube filing. Care for a EGT-bung? Or six All done Hope you like it. RE: OM Exhaust Manifold Thread - willbhere4u - 05-16-2014 Nice what kind of EGT gauge are you going to run RE: OM Exhaust Manifold Thread - MFSuper90 - 05-16-2014 Looks like ports for Corsa datalogger or something similar, where it logs all data into a computer from each and every cylinder. Very cool technology. RE: OM Exhaust Manifold Thread - raysorenson - 05-16-2014 That corsa thing is insanely expensive. That's pricing from ten years ago. Check out 14point7's $200 idash. Makes the corsa look obsolete. http://www.14point7.com/products/idash RE: OM Exhaust Manifold Thread - F.R.A.S - 05-16-2014 Thanks guys. This is for a customer in Holland (The Netherlands), he will run six normal analog EGT-gauges. A lot of gauges but at least he will be safe when going for maximum power. I believe this will be the fastest diesel car in Holland Right now Dieselmeken is building an awesome IP for him RE: OM Exhaust Manifold Thread - ben2go - 05-16-2014 (05-16-2014, 02:09 PM)F.R.A.S Thanks guys. This is for a customer in Holland (The Netherlands), he will run six normal analog EGT-gauges. A lot of gauges but at least he will be safe when going for maximum power. I believe this will be the fastest diesel car in Holland Any info on that IP? RE: OM Exhaust Manifold Thread - F.R.A.S - 05-16-2014 8mm But other than that there are no special stuff done what I know of RE: OM Exhaust Manifold Thread - F.R.A.S - 08-05-2014 Did a om605 exhaust manifold last week, finished it of today. Enjoy! RE: OM Exhaust Manifold Thread - F.R.A.S - 09-03-2014 om606 exhaust manifold for you guys. RE: OM Exhaust Manifold Thread - F.R.A.S - 10-21-2014 One of the biggest failures I've seen yet. om603 And people are actually paying for this stuff Here's another one! om605 RE: OM Exhaust Manifold Thread - winmutt - 10-21-2014 Thats special. RE: OM Exhaust Manifold Thread - raysorenson - 10-21-2014 I've been looking for a pic of an F-tune divided collector, 6 cyl specifically. Are yours better than these? :p RE: OM Exhaust Manifold Thread - F.R.A.S - 10-22-2014 Hahaha, yea we are We do very little divided actually, but that's the customers choice. How ever if going divided on a 6cy we recommend that you go for a t4 flange instead of a t3. Fitting 3cyl in to less than half a t3 is not super efficient. I actually don't have a picture either on the computer or my trusted phone (aka camera of choice). (10-21-2014, 07:34 PM)raysorenson I've been looking for a pic of an F-tune divided collector, 6 cyl specifically. Are yours better than these? :p RE: OM Exhaust Manifold Thread - Hario' - 10-22-2014 The above 603 manifold looks like my towel rail. RE: OM Exhaust Manifold Thread - Duncansport - 10-22-2014 Look, im a welder! RE: OM Exhaust Manifold Thread - raysorenson - 10-22-2014 (10-22-2014, 07:14 AM)Duncansport Look, im a welder! Fixed. I guess they were blowing on it for shielding gas RE: OM Exhaust Manifold Thread - F.R.A.S - 10-22-2014 Ohhh my god Duncan. That's the best yet. RE: OM Exhaust Manifold Thread - MFSuper90 - 10-22-2014 FRAS, how much would a t3 603 manifold cost about? Those cast w140 mainfold are hard to find! RE: OM Exhaust Manifold Thread - F.R.A.S - 10-23-2014 Send me a message mate. (10-22-2014, 10:17 PM)MFSuper90 FRAS, how much would a t3 603 manifold cost about? RE: OM Exhaust Manifold Thread - Duncansport - 10-23-2014 Last one.. i promise :-P RE: OM Exhaust Manifold Thread - winmutt - 10-23-2014 (10-22-2014, 10:17 PM)MFSuper90 FRAS, how much would a t3 603 manifold cost about? I got mine from ebay.de for ~250 shipped. RE: OM Exhaust Manifold Thread - MFSuper90 - 10-23-2014 (10-23-2014, 08:31 AM)winmutt(10-22-2014, 10:17 PM)MFSuper90 FRAS, how much would a t3 603 manifold cost about? I've been searching high and low, guess I'm at the waiting game now My hx30 won't mount to the original manifold RE: OM Exhaust Manifold Thread - EDH_Performance - 10-28-2014 (10-23-2014, 02:36 PM)MFSuper90(10-23-2014, 08:31 AM)winmutt(10-22-2014, 10:17 PM)MFSuper90 FRAS, how much would a t3 603 manifold cost about? Make an adapter? RE: OM Exhaust Manifold Thread - capflya - 10-28-2014 (10-28-2014, 08:11 AM)EDH_Performance(10-23-2014, 02:36 PM)MFSuper90 I've been searching high and low, guess I'm at the waiting game now The flange is right but the US manifolds won't allow a large turbo to fit because of the bypass pipe for the trap ox garbage Mbz put on the cars here. RE: OM Exhaust Manifold Thread - MFSuper90 - 10-28-2014 (10-28-2014, 08:11 AM)EDH_Performance(10-23-2014, 02:36 PM)MFSuper90(10-23-2014, 08:31 AM)winmutt I got mine from ebay.de for ~250 shipped. It hangs the turbo in the opposite direction on the trap-ox manifolds, so my exhaust would be towards the radiator and inlet towards the firewall. It would just Be easier to use a non- trap ox manifold RE: OM Exhaust Manifold Thread - DiseaselWeasel - 10-28-2014 What do euro-603 manifolds sell for in the US? RE: OM Exhaust Manifold Thread - capflya - 10-28-2014 I've heard of a range... $250-$350 including shipping. I think someone here got one from ebay.de for $275 shipped to the US? If you can source some I think we have a market... I'm looking for one if the price is right and a friend of mine would be in for one or two. RE: OM Exhaust Manifold Thread - F.R.A.S - 11-13-2014 om604 8mm Diselmeken IP, gt3076r a/r 0,63 Thermal barrier coating on exhaust manifold and turbine housing. RE: OM Exhaust Manifold Thread - Eric78 - 12-01-2014 Anyone remember the URL of the site that sells a copy of Jeemu's OM 605 exhaust header? RE: OM Exhaust Manifold Thread - F.R.A.S - 03-19-2015 om617 getting there RE: OM Exhaust Manifold Thread - Captain America - 03-19-2015 Nice! I'll take one! RE: OM Exhaust Manifold Thread - Matej - 06-26-2015 Could anyone make an adapter flange to bolt an OM603 manifold onto an OM606 head? Something similar to the Dieselmeken flange, but with extra threaded holes for attaching the 603 manifold and with the size of the round outlet ports matching. I will buy one right away. RE: OM Exhaust Manifold Thread - hents99 - 06-27-2015 Something like this? Bolt pattern is very tight. It`s OM606 flange with OM603 bolt holes. RE: OM Exhaust Manifold Thread - hents99 - 06-28-2015 Here is E36 turbo manifold I made to my friends car some years ago. Will not fit I suggest you to make new custom manifold for your engine. Fitting another manifold is really PITA. Position of turbo can`t be change and so on. I have many exhaust flange drawings. I can check what engines have same cylinder spacing like OM606. RE: OM Exhaust Manifold Thread - CRD4x4 - 06-28-2015 I've been looking into using other non-MB manifolds too and have found only one possible candidate which is early Jaguar 4.2L inline but turbo manifolds are not common. I overlay a OM606 exhaust manifold gasket and the port spacing seems identical except that the Jag ports are rectangular. Can anyone recommend a free site I can use to share my pix? RE: OM Exhaust Manifold Thread - Booster - 06-28-2015 (06-28-2015, 08:05 AM)CRD4x4 I've been looking into using other non-MB manifolds too and have found only one possible candidate which is early Jaguar 4.2L inline but turbo manifolds are not common. I overlay a OM606 exhaust manifold gasket and the port spacing seems identical except that the Jag ports are rectangular. Use Photobucket. Its free and fairly easy to use. RE: OM Exhaust Manifold Thread - CRD4x4 - 06-28-2015 (06-28-2015, 01:07 PM)Booster(06-28-2015, 08:05 AM)CRD4x4 I've been looking into using other non-MB manifolds too and have found only one possible candidate which is early Jaguar 4.2L inline but turbo manifolds are not common. I overlay a OM606 exhaust manifold gasket and the port spacing seems identical except that the Jag ports are rectangular. My thinking was to weld on a OM606 flange and port match these then use for a turbo set up. RE: OM Exhaust Manifold Thread - F.R.A.S - 07-01-2015 (06-26-2015, 04:21 PM)Matej Could anyone make an adapter flange to bolt an OM603 manifold onto an OM606 head? Hey man thats OUR flange not Dieselmekens RE: OM Exhaust Manifold Thread - Matej - 07-01-2015 (07-01-2015, 03:03 AM)F.R.A.S Hey man thats OUR flange not DieselmekensSorry, did not even know that, I just assumed it was his since he was selling it. It is a very nice piece. As I said above, if it would be possible to make one to adapt a 603 manifold to the 606 head, I will buy one ASAP. RE: OM Exhaust Manifold Thread - F.R.A.S - 07-06-2015 I don't think we have a om603 flange on the shelf today otherwise I could help you out right away Will take cruise around the welding area in a moment RE: OM Exhaust Manifold Thread - Simpler=Better - 07-06-2015 F-Tune, you guys made some crazy shit RE: OM Exhaust Manifold Thread - F.R.A.S - 07-07-2015 (07-06-2015, 10:07 AM)Simpler=Better F-tune, you guys made some crazy shit Thanks mate RE: OM Exhaust Manifold Thread - F.R.A.S - 02-29-2016 Did a more "normal" flange for a customer. As you understand the customer will weld his own exhaust manifold on this and therefore we don't put any work in to the surface finish. RE: OM Exhaust Manifold Thread - atypicalguy - 08-28-2016 Half of a new 606 manifold from the same guy who made Sultzi's, Pyry Takkunen. |
