C111-IId and C111-III details from Mercedes - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: C111-IId and C111-III details from Mercedes (/showthread.php?tid=359) Pages:
1
2
RE: C111-IId and C111-III details from Mercedes - Volker407 - 01-22-2014 some more pictures from the meeting at Schloß Dyck http://www.nast-sonderfahrzeuge.de/MB-Exotenforum/forum_entry.php?id=37218 http://www.formfreu.de/2010/08/08/mercedes-benz-c-111-iid-classic-days-schloss-dyck/ Can somebody confirm or correct me that the turbocharger looks like a Garrett T04B? What size would that turbo be compared to a Holset for example? Gruß Volker RE: C111-IId and C111-III details from Mercedes - tjts1 - 01-22-2014 Can somebody translate? ![]() RE: C111-IId and C111-III details from Mercedes - Tito - 01-22-2014 After full load, don't turn the engine off immediately. Probably to cool the turbo of course... Edit: left 2 buttons say pump L and pump R. Kraftstoff means fuel. So some kind of fuel supply. Zuending I don't know for sure but i thought it was ignition. Starter, well seems obvious. And licht mean lights. I think the white card is the calculated speed. 3,4,5 Gg are probably the gears (in german = gang)? and the engine RPM on top. Reifen translates to tires and the size is 215/70VR15 HA = hinterachse meaning rear axle (differential). That would be the final drive ratio = 3.07 RE: C111-IId and C111-III details from Mercedes - winmutt - 01-22-2014 Ditto on what Tito said. How in the world can they get 170mph out of that gearing? http://wahiduddin.net/calc/calc_speed_rpm.htm says 146.6MPH assuming 5th OD is 0.83 (normal 5th right). According to the calculator their 5th gear is 0.71!!!! RE: C111-IId and C111-III details from Mercedes - Volker407 - 12-22-2014 Look out for news, due to a press release 2015 will be "The year of the C111" with several presentations and a special C111 exhibition at the Mercedes Museum in Stuttgart. V8 https://www.youtube.com/watch?v=6J1eZ65SgkE original OM617A sound https://www.youtube.com/watch?v=KR8n-8W2bOM Gruß Volker RE: C111-IId and C111-III details from Mercedes - Greazzer - 12-22-2014 Great Stuff ! RE: C111-IId and C111-III details from Mercedes - Volker407 - 11-12-2015 A few days ago I have been to the Museum Gruß Volker RE: C111-IId and C111-III details from Mercedes - NZScott - 11-13-2015 Woooow, nice. I'm a little confused as to which engine this is though. Going by the lack of oil filter housing the block is a 617.910? Which would've been used for the 1976 trials presumably, but the info panel says 1980? The other pics of the C111-IID have the normal filter housings. I see the head has the SLS drive blocked off, did the W115s even have SLS? Jeez this raises more questions than it answers ![]() PS- didn't happen to see a part number on that vacuum pump block off plate? lol RE: C111-IId and C111-III details from Mercedes - Volker407 - 11-22-2015 (11-13-2015, 01:44 AM)NZScott Woooow, nice. I'm a little confused as to which engine this is though. Going by the lack of oil filter housing the block is a 617.910? Which would've been used for the 1976 trials presumably, but the info panel says 1980? The other pics of the C111-IID have the normal filter housings. I see the head has the SLS drive blocked off, did the W115s even have SLS? They basically took the engine from a W115 240 3.0D The oil filter connection is below the injection pump. On the old pictures the oil filter is not the stock one. Keep in mind that there were at least 3 engine versions. The "C111 orange Diesel 1" , "C111 orange Diesel 2" and the later "silver Diesel streamliner". The cast number on the engine block indicates, that those engine blocks were an extra casting with some missing holes so they could drill the holes later were they need them. But still a standard OM617 block. They then did add several holes for the oil filter, piston cooling and so on. The engine also did get stronger rods, different crankshaft, special turbo pistons, bigger piston pins,.... Those upgrades were always related to the naturally aspirated engine from the W115. So the later turbo engine which you could buy in every car is very similar to the engine that drove the records. There are some small changes like the record car had sodium filled inlet and outlet valves. The later production engine only has the outlet valves filled with sodium. Oh and forget about what the info panels say. They were written by marketing guys.... The SLS drive on the head is probably just a "power take-off" in reserve. Maybe they would have needed an additional water pump, oil pump or whatever. On such a car you want to keep all possibilities. Sorry, no part number on the block off plate ;-) Gruß Volker RE: C111-IId and C111-III details from Mercedes - NZScott - 11-23-2015 I checked some pics and indeed the oil filter on the earlier cars was a remote one, but still the cartridge style. I was not aware of 3 versions of the engine, thought there was the IID (orange) of 1976 (190hp) then the silver IIID of '78 (230hp)? I notice too the head has the pencil glow plugs so maybe the head was changed, would explain the SLS drive blocked off. Very interested in the mods you mention, in the middle of chucking a holset on a 617.912 for 150hp or so you see ![]() Well what a shame ![]() |
