10mm Element Thread - Printable Version
+--- Thread: 10mm Element Thread (/showthread.php?tid=716)
Pages: 1 2 3 4
RE: 10mm Element Thread - benztek - 11-09-2009
I Completely agree that the engine cant handle all the 10mm will put out. Once tuned as best as possible we are talking about a larger turbo than anyone has hung from a 617 yet. Is it time to look into fabricating an exhaust header?
RE: 10mm Element Thread - 300SD81 - 11-09-2009
Sweet! Can't wait to see what kind of power you get outta this!
Didn't I read somewhere that the rate of injection effects the efficiency of the engine or something, so bigger elements were better than small ones turned up?
That engine sounded pretty awful to me, but I'm hoping that its just because I'm not used to hearing one with no exhaust at all... Any updates on the leak or timing adjustments?
RE: 10mm Element Thread - GREASY_BEAST - 11-09-2009
Does someone have hard numbers on the internal limits of the stock 617? I remember reading a number like 400N*m (~300ft*lb) for the torque output... If that is the case, then the 617 is limited to pretty low HP numbers and it doesn't matter how big a turbo you hang on it... anyone know for sure, or do we have to break an engine to find out?
RE: 10mm Element Thread - tomnik - 11-10-2009
(11-09-2009, 05:24 PM)GREASY_BEAST Does someone have hard numbers on the internal limits of the stock 617? I remember reading a number like 400N*m (~300ft*lb) for the torque output... If that is the case, then the 617 is limited to pretty low HP numbers and it doesn't matter how big a turbo you hang on it... anyone know for sure, or do we have to break an engine to find out?
Hi,
torque is in direct relation with the amount of fuel.
250 Nm corresponds to approx. 55 ccm/1000 revs.
400 Nm will roughly need 90 ccm/1000 revs.
Yesterday night I had the MW65 Holly IP running the first time. The current adjustment is 78 ccm/1000 revs and it did not smoke even without ADLA mounted. VTG with vanes fixed open, free flow exhaust, just running a couple of minutes after cold start, no driving.
I am sure even more fuel is possible.
Tom
RE: 10mm Element Thread - willbhere4u - 11-10-2009
yes videos please! what is the basic cost of buying elements and then setting up a pump???
RE: 10mm Element Thread - GREASY_BEAST - 11-10-2009
(11-10-2009, 12:50 AM)tomnik Hi,
I'll try to post a short video later.
Tom
Thats interesting info, Tomnik, thank you. I can't wait to see video! I was mostly concerned in my question, however, about how much torque the crankshaft be subjected to without breaking. If I remember correctly it wasn't a very big number, but I don't remember the source of this information.
RE: 10mm Element Thread - benztek - 11-10-2009
[/quote]
I would like to find out where you got that information. Talking with a few of the older guys around the shop here they seem to believe that the crank is the strongest part of the 617. They seem to believe that there will be head gasket issues before we reach mechanical failure. But who really wants to put all these "guesses" to the test?
RE: 10mm Element Thread - George3soccer - 11-10-2009
Very Very interested, loving it all so much.
RE: 10mm Element Thread - shredator - 11-10-2009
(11-09-2009, 11:48 AM)benztek what size turbo is going to be needed to make use of all the extra fuel?
IF this works out, I am planning on trying to compund an he351ve and a gt2256v. And yeah, tubular header for sure. But that will be a whole 'nuther adventure, and thread.Wink
(11-09-2009, 02:29 PM)ForcedInduction Myna's 7mm pump supports 450hp on a 5-cylinder, 10mm elements can pump a hair over twice that amount of fuel. Big Grin
Do we know that the strokes are the same between the M and MW pumps? It seems that the M pumps deliver more hp per mm^2 of plunger size. from my back-of-the-envelope calc scaling HP by the plunger area, 10mm should be good for ~460hp with the MW. However it doesnt seem right that the M would have roughly double the stroke of the MW. What else could account for the discrepancy?
(11-09-2009, 02:33 PM)winmutt Have your tried dialing the rack dampener all the way in?
in order to preserve the sanity of my neighbors (and cats) I need to get the thing muffled somehow before I start it up on a more frequent basis in order to 'tune it up'. But ill see if i can try that out tomorrow.
GREASY_BEAST anyone know for sure, or do we have to break an engine to find out?
I have accepted the fact that I will probably end up breaking something (or many things) as a result of this project.
benztek But who really wants to put all these "guesses" to the test?
I do!Big Grin
RE: 10mm Element Thread - ForcedInduction - 11-10-2009
(11-10-2009, 04:09 PM)shredator Do we know that the strokes are the same between the M and MW pumps?
Both are an 8mm stroke.
well you cant brag about power! untill you blow something up!!!! lol looking forward to seeing this build!!!
RE: 10mm Element Thread - tomnik - 11-11-2009
Hi,
here is the little video:
http://www.youtube.com/watch?v=eLY8jWDlR-w
The engine started up approx. 20 sec before the video start for the first time after installing the MW65 Holly IP. The bench data of this IP are posted earlier. Begin of delivery not checked and adjusted yet.
Tom
RE: 10mm Element Thread - benztek - 11-11-2009
I do!Big Grin
You are a man after my own heart!!!!
RE: 10mm Element Thread - Tymbrymi - 11-11-2009
Shredator and Tomnik, a big THANK YOU for being pioneers in actually doing something significant for real power. Cool Up to this point everything has been all talk and speculation without any real results. I sure hope you guys have dynos nearby when you get the cars together! Big Grin Best of luck to the both of you in keeping these projects rolling!
Tomnik, I like the socket on the valve cover to show how smooth the engine is. Cool
RE: 10mm Element Thread - winmutt - 11-11-2009
(11-11-2009, 10:22 AM)Tymbrymi Tomnik, I like the socket on the valve cover to show how smooth the engine is. Cool
No kidding, I wish mine was that smooth. It was before I turned the elements. Are the Holly elements a drop in or do you have to remove the crank?
(11-11-2009, 11:03 AM)winmutt No kidding, I wish mine was that smooth. It was before I turned the elements. Are the Holly elements a drop in or do you have to remove the crank?
All element swaps need the cam to be removed. On the MW the cylinder only but not for the plunger.
The smooth run is balanced quantities (see my bench post earlier) and correct start of delivery of the single cylinders. No miracle, just good quality elements and correct work on the bench.
Tom
RE: 10mm Element Thread - shredator - 11-11-2009
I tried advancing the timing to ~27btdc, and messed around with the damper screw. neither really seemed to make a big difference. This morning, I really tried to concentrate on listening to the klatter sound from the engine instead the gurgle from the exhaust. once I did this, I realized that the idle quality and throttle response are not really that bad. I cant say for certain if it is really any worse than the stock engine. Ill make another vid once I get the thing muffled, and let other folks judge.
Even with the advanced timing, the engine still smokes at idle more than it should. Should I keep advancing the timing? retard the timing? it seems to me that the larger elements would provide a faster injection, and not need as much advance. if there was too much fuel, the engine would just idle faster right? could it be caused by me running it with the intake and exhaust manifolds open causing the engine to breathe oxygen-depleated air? Im baffled.Huh
RE: 10mm Element Thread - willbhere4u - 11-11-2009
I would get the intake and exhaust separated and see ho it runs it needs some cool fresh air!!!
RE: 10mm Element Thread - GREASY_BEAST - 11-11-2009
(11-11-2009, 08:00 PM)willbhere4u I would get the intake and exhaust separated and see ho it runs it needs some cool fresh air!!!
I would leave the timing stock for now, and get it driving before messing around too much. Timing shouldn't change all that much with bigger elements. The fact that its idling so smoothly, responding so well to throttle inputs, AND returning to idle so well, is encouraging. The smoke might seem worse than it actually is with the manifolds off and it "in your face" like that. See what it looks like with the exhaust, turbo, and intake hooked up. Even if it does smoke a little... you have limitless power on tap with the mere turn of a screw.
RE: 10mm Element Thread - tomnik - 11-12-2009
I also would stay with stock timing. Rather going late than advancing.
But your idle quantity is about double compared to stock. At idle you don't have enough air to burn it completely. You should drive the car before messing around with everything.
Tom
RE: 10mm Element Thread - 300SD81 - 11-12-2009
I think you got that from the C111. Hopefully, thats not the maximum possible torque.
RE: 10mm Element Thread - ForcedInduction - 11-12-2009
(11-12-2009, 02:27 AM)300SD81 Hopefully, thats not the maximum possible torque.
Thats because it used a big non-wastegated turbo. If a wastegated or VNT turbo were used, the torque peak would increase and shift to a much lower RPM with the same fueling settings.
RE: 10mm Element Thread - GREASY_BEAST - 11-12-2009
(11-12-2009, 05:26 AM)ForcedInduction the torque peak would increase and shift to a much lower RPM with the same fueling settings.
Which might make the crank very, very unhappy... and the trans, rear tires, etc.. that is, you would be limited in max HP by the virtue of too much low end torque. Apparently people who tune 1.9L VWs have a similar problem, too much torque too low.
A simple RPM switch can take care of that. Limit boost until a safe RPM and the aneroid will keep smoke under control.
RE: 10mm Element Thread - willbhere4u - 11-12-2009
In all of my racing years I have never seen a crank fail!!!! and I have seen a suzuki 1.3 Huyabusa turbo put 600hp on a dyno!!!!
plus the Mercedes has a big beefy crank!!! I would be more worried about rods or pistons before the crank and they are pretty stout as well!!!
RE: 10mm Element Thread - Tymbrymi - 11-13-2009
Don't forget that power is torque x RPM. If all you're going to do is the stock max RPM, it will of course be limited by the torque. If you spin the engine like the Finns do then you can make some of their HP numbers. Admittedly, the 617 probably won't spin as fast as a 603, but we certainly have overhead in the RPM department. Smile
RE: 10mm Element Thread - GREASY_BEAST - 11-14-2009
Guess I'm wrong about the crank then.. I swear I remember reading some speculation about it. In any case, it seems we are about to learn a whole lot about the performance potential of the 617!
RE: 10mm Element Thread - Kiwibacon - 11-14-2009
As the owner of a 3.9L diesel with 520+Nm (from 330ish stock) I'll give some of my findings.
For a start, there's a difference between having torque and having usable torque.
If you double the torque, you double the amount of torsional oscillation, unless you also double the flywheel inertia (or already have a monster flywheel) then you can get severe vibration problems at low rpms.
This is where I'm currently at. I can get 17psi boost at 1400rpm and 20psi from about 1700rpm, but can't use it smoothly until I'm closer to 2000rpm.
Secondly, more torque down low is far more useful than higher revs in real driving. Unless you're doing 1/4 miles and dyno runs of course.
Thirdly, cylinder pressure. You guys are running indirect injection engines with high compression. The combination of fuel loading, boost and timing is going to have to be balanced carefully. Whether you guys find the top end or bottom end is the weak point will be interesting. Retarding injection timing might be needed to save the day.
RE: 10mm Element Thread - ForcedInduction - 11-14-2009
(11-14-2009, 02:58 AM)Kiwibacon Retarding injection timing might be needed to save the day.
I don't know about that.
Listen to the timing nailing of this 445hp OM605.
http://www.youtube.com/watch?v=4VwpNktflAw
Granted, its probably got really beefed internals to handle the power so smoothly....
(11-14-2009, 03:08 AM)ForcedInduction
You call that smoothly?Confused
It's not about the noise though, it's about internal stress. Shifting the pressure pulse further after TDC reduces stress a lot. The alternatives like reducing compression ratio are a lot more involved.
RE: 10mm Element Thread - tomnik - 11-15-2009
(11-14-2009, 03:22 AM)Kiwibacon It's not about the noise though, it's about internal stress. Shifting the pressure pulse further after TDC reduces stress a lot. The alternatives like reducing compression ratio are a lot more involved.
Kiwi,
this is what runs my brain hot since days. I am currently searching for a optimal end of injection depending on engine crank position. This came in my head when reviewing the calculation of the larger elements. The duration for injection is shorter and now I wonder how much I can retard the timing with larger elements to end my injection earlier than stock (for more complete burning of the fuel) AND to start injection later with the larger elements to get additional benefits regarding efficiency and engine stress (besides a very smooth run).
If I don't find information in some books I will make the calculation with an IP on the table.
Tom
RE: 10mm Element Thread - Kiwibacon - 11-15-2009
(11-15-2009, 02:32 AM)tomnik Kiwi,
Tom
This is my thinking also.
My 4wd runs an A pump with 10mm elements. Stock injection volumes are around 70 cc/1000 shots. A pumps with I think 9mm elements have been measured at 140cc/1000 shots max.
I don't know how the A pump compares to yours for stroke.
it's not only the volume, but the higher the volume (max. full load setting) the later the end of injection on the same IP with the same elements.
We learned that a maxed out IP with small elements will produce black smoke instead of giving all the power of the added fuel, so end of injection is probably too later to burn completely even with enough air.
Now my intention is to first fix a max volume and depending on that retiming the IP direction late. At the end of the day there will be a table with max volumes and related timing (for the same element of course).
The question still is: How is the range of injection placed over engine crank position? Is the 24 deg BOD only because of the burning velocity of diesel?
On veggie which is way slower in burning the difference of engine run is not so big. But why then the 24 deg BOD?
Trial and error looking for the lowest EGT when changing timing step by step??
Tom
RE: 10mm Element Thread - GREASY_BEAST - 11-15-2009
(11-15-2009, 05:56 AM)tomnik iIs the 24 deg BOD only because of the burning velocity of diesel?
Tom
Ignition/burn characteristics also depend on the specific heat capacity of the fuel, and cylinder temperature at crank position (theta). Injecting all the fuel really quickly too early will probably result in nailing/grey-black smoke (like when the timing on stock elements is too advanced). I agree that the timing should be retarded slightly (probably), but I would venture a guess that to calculate this would be VERY involved. It is probably better to just look at EGTs, smoke, and running characteristics of the engine over the entire RPM range to obtain a good timing range by trial and error.
Also, with the bigger elements, increasing the injection pressure should not be necessary to obtain better atomization, and is probably a bad idea because the big elements already put a LOT more stress on the IP camshaft. Inherently better atomization is another thing that makes me lean towards retarded timing giving better running characteristics... Although I'm not a diesel engine guru...
However, if you look at the original poster's video, that engine runs pretty damn well, just a little smoky. This means that any timing adjustment that needs to be made shouldn't be too severe (if a timing adjustment would actually solve the "problem").
The problems from too far retarded are poor starting and white smoke. If you're not getting either of those then there's scope to retard injection timing further.
Personally I find black smoke appalling. It's bad for the air we breathe, bad for your engine and bad for the public perception of diesel engines. The same people run dirty tunes which belch black smoke are often the ones who complain about the availability of diesel vehicles in the US.
RE: 10mm Element Thread - benztek - 11-19-2009
Any updates on your progress?
RE: 10mm Element Thread - shredator - 11-20-2009
bolted the turbo back up. Need to order the hoses and fittings necessary to supply oil to the turbo from the new filters. Unfortunately, money has been diverted out of the car fund and into the not-going-into-debt-while-keeping-the-fiancee-happy-during-the-holidays fund. So things will have to wait a while. yeah I can hear you all making those whip-crack noises. ha ha.
RE: 10mm Element Thread - 300SD81 - 11-21-2009
(11-20-2009, 02:43 PM)shredator bolted the turbo back up. Need to order the hoses and fittings necessary to supply oil to the turbo from the new filters. Unfortunately, money has been diverted out of the car fund and into the not-going-into-debt-while-keeping-the-fiancee-happy-during-the-holidays fund. So things will have to wait a while. yeah I can hear you all making those whip-crack noises. ha ha.
Comeon! Hose clamps and fuel injection hose will hold for a few minute test run Big Grin
RE: 10mm Element Thread - GREASY_BEAST - 11-21-2009
[/quote]
Please don't do this!! Big Grin Take your time, shredator. Awesome project.
RE: 10mm Element Thread - benztek - 12-09-2009
Is it back together yet? I really just wanted to bump this!
RE: 10mm Element Thread - GREASY_BEAST - 12-23-2009
bump Big Grin
RE: 10mm Element Thread - Kiwibacon - 12-23-2009
(11-09-2009, 02:29 PM)ForcedInduction There is no possible way the engine can handle anything remotely close to what 10mm elements can pump out. Myna's 7mm pump supports 450hp on a 5-cylinder, 10mm elements can pump a hair over twice that amount of fuel. Big Grin
Bigger elements provide shorter injection for the same volume. That's gotta be a bonus as the revs rise and the injection window gets shorter.
(12-23-2009, 04:09 PM)Kiwibacon Bigger elements provide shorter injection for the same volume. That's gotta be a bonus as the revs rise and the injection window gets shorter.
why?
RE: 10mm Element Thread - ForcedInduction - 12-23-2009
(12-23-2009, 04:09 PM)Kiwibacon That's gotta be a bonus as the revs rise and the injection window gets shorter.
It can also quench the flame front. Until shredator gets it running with higher power, we won't know.
(12-23-2009, 05:37 PM)GREASY_BEAST
why?
Because diesel burns at a fixed speed, so as your rpms rise injection has to be advanced more and more to get peak pressure happening just after TDC. Eventually you're advanced so far that you can't burn the fuel that's injected then, it gets charred and exits the engine as black smoke. Wasted fuel.
Shorter injection time means you don't need to advance quite as far, resulting in less black smoke and wasted fuel. Cleaner burn, more power from the same fuel etc.
RE: 10mm Element Thread - GREASY_BEAST - 12-24-2009
(12-23-2009, 11:28 PM)Kiwibacon Because diesel burns at a fixed speed, so as your rpms rise injection has to be advanced more and more to get peak pressure happening just after TDC. Eventually you're advanced so far that you can't burn the fuel that's injected then, it gets charred and exits the engine as black smoke. Wasted fuel.
Okay, now lets assume that the fuel all injects instantly (perfectly atomized). This is also bad, but the reason is more complicated. If fuel injects over some delta_t such that one end of the stream ignites before the other end has left the nozzle, this affects a situation analogous to pre-injection, and creates a flame front which propagates evenly. Right? What happens when all the fuel goes in before any of it ignites?
RE: 10mm Element Thread - tomnik - 12-24-2009
Kiwi,
you're not quite correct.
Begin of delivery is the same just the end of injection is earlier with larger elements. This could be used to delay begin of delivery and inject into a hotter cylinder atmosphere which is positive for ignition also positive is a better spray that comes from same quantity within shorter time.
Let's assume the pre spray ignites then you spray too much fuel into this flame (at that time we are already after TDC) we could risk that the amount of fuel does not burn well and fast enough to be complete before the valves open.
This is exactly the reason why I want to run a pressure data log of the cylinder inside pressure curve to see where I am.
Tom
RE: 10mm Element Thread - Kiwibacon - 12-24-2009
(12-24-2009, 07:57 AM)tomnik Kiwi,
Yes, this is what I mean. Because all the fuel is injected sooner, the injection doesn't have to start as early. This can help avoid the problems with very advanced injection at high rpms.
This will however mean a faster pressure rise and high peak forces on the engine.
Engines do suffer when we crank up the power.
How do you plan to log cylinder pressure? A transducer in the glow-plug hole?
(12-24-2009, 04:37 PM)Kiwibacon This will however mean a faster pressure rise and high peak forces on the engine.
it will not suffer when the pressure peak comes in time with downwards movement of the piston. To get there it the pressure log is necessary.
yes, transducer in glow-plug hole.
I don't have the equipment but the local university might help.
Tom
