Purple turbo 240D - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: Projects (https://www.superturbodiesel.com/std/forumdisplay.php?fid=14) +--- Thread: Purple turbo 240D (/showthread.php?tid=3076) |
RE: Purple turbo 240D - Purplecomputer - 06-20-2013 (06-19-2013, 05:53 PM)willbhere4u If you want it to stay clean replace the axle seals also. They are pretty easy while the CV joints are out thanks! didnt even know you should change it. RE: Purple turbo 240D - Simpler=Better - 06-20-2013 (06-20-2013, 11:44 AM)Purplecomputer(06-19-2013, 05:53 PM)willbhere4u If you want it to stay clean replace the axle seals also. They are pretty easy while the CV joints are out Oh you will know. I have to do the pinion seal on the jeep and it's gonna be fuuuuuuun! RE: Purple turbo 240D - Purplecomputer - 06-21-2013 holy shit! what a day! been running around all day getting some stuff done while working on the car so I spent a good chunk of my time jut trying to remove the axles ![]() heres the old compared to the new, I went with the EMPI ones becuase if i ever have to do this job again I just unscrew some bolts off the axle and replace it, no more having to drop the differential, open it up....and such ![]() the differential itself was really clean, I took a flashlight and visually inspected for chips and wear but nothing, I am happy about that at least probaby two hours later from that point here are the axles installed left side ![]() right side ![]() maybe tomorrow or monday I will fill it back up with gear oil and mount it. from there I will work on the breaks. really want to make it to the GTG in Pa on august 24th. RE: Purple turbo 240D - willbhere4u - 06-21-2013 Get synthetic oil it there it defiantly made a difference on my cars mpg after doing the eng trans and diff I got about 2-3 mpg better highway driving RE: Purple turbo 240D - Purplecomputer - 06-22-2013 Question, Do I need to put a seal on the differential cover? The car didn't have one and my pops recommends either using gasket maker or seeing if they do have a seal at the store. RE: Purple turbo 240D - Simpler=Better - 06-22-2013 clean the surface, and put a thin film of RTV on there. Bolt it up and you're good-just DO NOT glop the RTV on, that causes problems. RE: Purple turbo 240D - Purplecomputer - 06-29-2013 Finished the CV axles. Ran out of money so I wont be able to work on the car for a while. things left to do -replace the exhaust or at least fix it -do the rear breaks ( new calipers and hoses) -fix the front end -get off my ass and finish putting together the vacuum pump -fix the front bumper just to name a few most of this stuff I could do in a few weeks now that im finished with summer classes dontations welcome ![]() RE: Purple turbo 240D - mbz123 - 07-07-2013 (06-29-2013, 02:49 PM)Purplecomputer Finished the CV axles. Thin smear of Grey RTV for rear diff. Let it tack then bolt cover on. With the syn and those annulars, odds are you'll never have to futz in that area on this car again. What might you be looking for parts wise. If it's not too wieldy and in my inventory, it might just be coming your way. MBZ123 RE: Purple turbo 240D - Purplecomputer - 07-07-2013 (07-07-2013, 01:46 AM)mbz123(06-29-2013, 02:49 PM)Purplecomputer Finished the CV axles. Yeah, thats the reason I went with the annular axles. Ill never have to do any of this pain in the ass stuff again. Right now Im saving up to get two new(rebuilt) ATE rear breaks and four break hoses for the front and back. to be honest thats really it, I have all the stuff for the vacuum pump and i just need to adjust the exhaust a little but, the guy who put it back in for me didnt do it right but it seems to be an easy job, might even just straight pipe. I was planning on redoing the front end (suspension and steering) but I want to get the car drivable. RE: Purple turbo 240D - Simpler=Better - 07-08-2013 The straight piped Garrett sounds great, and has an awesome whine when you shut the car down. But it is a bit loud, I'd toss a straight through muffler on there for good measure. The stock 300D turbo muffler would be a good choice. RE: Purple turbo 240D - Purplecomputer - 07-09-2013 (07-08-2013, 08:15 AM)Simpler=Better The straight piped Garrett sounds great, and has an awesome whine when you shut the car down. But it is a bit loud, I'd toss a straight through muffler on there for good measure. The stock 300D turbo muffler would be a good choice. those were my original intentions. I did run the car with just a down pipe for a while and it did sound awesome but i think I lost some hearing. Once I put on a muffler it was night and day difference! RE: Purple turbo 240D - Purplecomputer - 07-09-2013 messed around on my arduino project for the car the problem i see if that the LCD takes up alot of pin. not sure If Ill have enough for senor. maybe adding another micro controller to control the LCD and another one for all the senors. anyways, heres a bit of coding mishap and all I got was funky text ![]() fixed it, didnt realize that you cant do the same stuff in java such as having the variable in the same line of code, have to declare it on a another spot ![]() i just have a fixed variable just to try. RE: Purple turbo 240D - Simpler=Better - 07-09-2013 Sign me up for one RE: Purple turbo 240D - Purplecomputer - 07-09-2013 (07-09-2013, 03:49 PM)Simpler=Better Sign me up for one im going to need a tester anyway seeing as my car is no longer working. maybe winmutt can recommend some sensors. the whole idea is to replace the ashtray like i did with my two gauges but replace those with the LCD screen. the arduino + lcd will take up considerable less space then gauges and should be somehwhat more reliable. any functions you guys can think of that I should put on this? Maybe an alarm to warn the driver of high temps or overboost. RE: Purple turbo 240D - w123love - 07-09-2013 (07-09-2013, 04:06 PM)Purplecomputer(07-09-2013, 03:49 PM)Simpler=Better Sign me up for one Muahhhaha you are literally making exactly what I bought from ZadaTech. Same LCD, boost, EGT, fuel pressure. Has a beeper and LED for overboost and exceeded EGT's. Its out of the car right now, but I am going to reinstall it in the ashtray. The wood on the ashtray will be a false front that can be removed to reveal the LCD gauge installed behind it. RE: Purple turbo 240D - Purplecomputer - 07-10-2013 (07-09-2013, 10:27 PM)w123love(07-09-2013, 04:06 PM)Purplecomputer(07-09-2013, 03:49 PM)Simpler=Better Sign me up for one I remember seeing it on your project thread. did it come with sensors and their part numbers? can I ask how much you paid for it? it im able to do it I would like to perhaps sell it. I am thinking about getting a 3D printer and custom print an ashtray that would hold all the components. found their site, the sensors they offer are expensive and they are pretty much just standard ones you find anywhere. to make them work I think I would need an amplifier. RE: Purple turbo 240D - Simpler=Better - 07-10-2013 (07-10-2013, 08:43 AM)Purplecomputer(07-09-2013, 10:27 PM)w123love(07-09-2013, 04:06 PM)Purplecomputer im going to need a tester anyway seeing as my car is no longer working. Shops will print things for you cheaper than you would think, you shouldn't have any trouble finding prototype shops being to close to NYC RE: Purple turbo 240D - Purplecomputer - 07-10-2013 (07-10-2013, 09:34 AM)Simpler=Better(07-10-2013, 08:43 AM)Purplecomputer(07-09-2013, 10:27 PM)w123love Muahhhaha you are literally making exactly what I bought from ZadaTech. Same LCD, boost, EGT, fuel pressure. Has a beeper and LED for overboost and exceeded EGT's. Its out of the car right now, but I am going to reinstall it in the ashtray. The wood on the ashtray will be a false front that can be removed to reveal the LCD gauge installed behind it. Makerbot has a shop somwhere in manhattan. They have free 3d software online that you can design and then send to be printed. http://www.123dapp.com/ RE: Purple turbo 240D - Purplecomputer - 07-11-2013 rainy day and ive been really into arduino now. figured out how to read data from a sensor and also figured out how to display that shit on an LCD check it son ![]() RE: Purple turbo 240D - Purplecomputer - 07-24-2013 so I tried to make myself useful today and finished rebuilding the vacuum pump. the reason I havent finished it was because of that stupid plastic sleeve but I said forget it and rebuilt it without it. I am probably going to install friday and see if I can get the car started and running for a bit just to make sure the pump works fine. RE: Purple turbo 240D - Purplecomputer - 07-26-2013 So today I installed the vacuum pump, Hooked everything back up and while doing this I was charging the battery. I took the key, prayed while the glow plugs were heating up and went for it. CLUG CLUG CLUG CLUG (Diesel engine noise) THE NOISE, THE SMELL, THE WHISTLING OF THE TURBO! It brought back life in me that I thought I had once lost. I feel so exhilarated, so happy, so proud of myself. as I sat in the driver seat I wondered why I had ever put off working on this car. For now I am going to finish the rear breaks and align the exhaust. Maybe during the fall I will fix the front end suspension and do the A/C before next summer. RE: Purple turbo 240D - Simpler=Better - 07-26-2013 Congrats! There's nothing more satisfying than the CLACK CLACK CLACK CLACK when you're done working ![]() The brakes are easy, just don't break anything while you're in there. RE: Purple turbo 240D - JB3 - 07-26-2013 (07-26-2013, 12:44 PM)Simpler=Better Congrats! There's nothing more satisfying than the CLACK CLACK CLACK CLACK when you're done working worst case scenario you can cap off a wheel or two. ![]() *My lawyers tell me that the above comment should only be taken in jest, and I accept no personal responsibility for any personal harm or property damage that results in application of the above jest in a real world setting.* Having reduced my liability, I will say that I drove around for 6 months while in tech school with 3 wheel brakes and one line capped off waiting on a caliper (or the money to buy the caliper more accurately). RE: Purple turbo 240D - Purplecomputer - 07-30-2013 (07-26-2013, 03:44 PM)JB3(07-26-2013, 12:44 PM)Simpler=Better Congrats! There's nothing more satisfying than the CLACK CLACK CLACK CLACK when you're done working well good news is that if i can get my hands on some rebuilt calipers and new pads ill have a running car. bad news im broke as shit. negative balance in my checking bills due and what not. Im on suicide watch so thats fun (jk) I did some free shit today, Removed all hoses pertaining to wvo system and fixed (sorta) the cooling system. also remove the muffler, thinking about sand blasting it and repainting it. noodie pics coming soon RE: Purple turbo 240D - JB3 - 07-30-2013 Im currently stripping a parts car that has some good OEM calipers on it if you are interested I could mail you for bargain basement price. I recently drove this car up from NY and wasn't killed as far as I can recall, so they seem to work well enough. RE: Purple turbo 240D - Purplecomputer - 07-30-2013 (07-30-2013, 04:10 PM)JB3 Im currently stripping a parts car that has some good OEM calipers on it if you are interested I could mail you for bargain basement price. I recently drove this car up from NY and wasn't killed as far as I can recall, so they seem to work well enough. I was planning on going 100% rebuilt after almost crashing the damn car in the rain because I had a seized caliper one day. I am however looking for some hoses for the cooling system. if the calipers are in good shape ill consider them. just let me know. I know I am sounding picky! RE: Purple turbo 240D - Simpler=Better - 07-31-2013 You're not picky, you just don't want to do it twice. Protip: if you're driving offroad and blow a brake line, a quick fix is to get a 6" preformed line from the autoparts store, cut it to 2", crimp it down over itself a few times, and install on the MC to block off the blown line. I have one in my toolbox in case I blow a rear line and need to limp home. When it seems like your car is always breaking it's annoying as hell, but you learn to live with imperfection. I'd rather have my old jalopy than all the nightmares and costs of a 2013 model. Plus it's already been proven-you know the weak spots (vac pump, oil cooler lines, etc.) on an old one. RE: Purple turbo 240D - Purplecomputer - 08-24-2013 okay! so I ordered the rest of the parts for the rear breaks. Shoutout to JB3 for being so kind enough to offer me used calipers at a great price (i turned them down though cause I was snobby and wanted new ![]() so I got everything installed, new hoses, calipers and pads. cleaned the rust off my rotors, bled the system and took it for a quick spin. breaks are weak, (need to keep bleeding it) and the worst thing is, this shit wobbles when you drive in the back. I suspect something is up the new axels. maybe wrong size? I dunno. I have a bbq today so ill take a look some other day. in the meantime, any ideas on the wobble issue? RE: Purple turbo 240D - larsalan - 08-24-2013 Is there persistent wobble? Sometimes I'm driving at a low speed and feel a wobble in the rear. Never had any problems at high speed. Maybe just on turning at low speed I feel some weirdness in the rear. RE: Purple turbo 240D - Purplecomputer - 08-25-2013 (08-24-2013, 04:15 PM)larsalan Is there persistent wobble? Sometimes I'm driving at a low speed and feel a wobble in the rear. Never had any problems at high speed. Maybe just on turning at low speed I feel some weirdness in the rear. well all i could really do was low speed. I dont have plates on the car so I just took it up and down the block. no power steering right now so it was a pain in the ass to maneuver RE: Purple turbo 240D - Purplecomputer - 08-28-2013 Update I checked for the reason concering the wobble in the rear end. turns out I forgot to tighten all my lug nuts on the driver side tire ![]() anyway, i have spent the past two days changing the brake hoses on the front end. Because it was sitting so long, everything kinda got rusted together. I was able to finish the passenger side no problem but I ran into a major issue on my driver side. The bolt holding down the brake hose got stripped and I ended up breaking the steel brake line in half Had to grind it off Do you guys think it was really necessary to change the hoses? They were all original to the car. ![]() ![]() Have to wait until Wednesday to order parts. RE: Purple turbo 240D - JB3 - 08-28-2013 Those rubber brake lines can dry crack, bubble, or internally delaminate causing brake drag or other problems. They are getting on in years, so problems are more likely, so it was probably a good bit of preventative maintenance to take care of them. Sucks that you have have to replace the steel line, but at least the driver side is a lot shorter and should be easy to replace it RE: Purple turbo 240D - Purplecomputer - 08-28-2013 (08-28-2013, 01:12 PM)JB3 Those rubber brake lines can dry crack, bubble, or internally delaminate causing brake drag or other problems. thanks for the reassurance! do you still have that parts car? I need a few things from ya. (08-28-2013, 01:12 PM)JB3 Those rubber brake lines can dry crack, bubble, or internally delaminate causing brake drag or other problems. thanks for the reassurance! do you still have that parts car? I need a few things from ya. RE: Purple turbo 240D - Simpler=Better - 08-28-2013 Get some flare wrenches from harbor freight, both Us an dmetric. Total is like $25, they're totally worth every cent. The only catch is the crappy HF ones have a really big radius on the edge of the hex, and you need to grind them down "clean" yourself. Not a big deal just a heads up. RE: Purple turbo 240D - JB3 - 08-28-2013 (08-28-2013, 01:15 PM)Purplecomputer thanks for the reassurance! I junked it, but what are you looking for? I stripped it fairly well, but a lot of stuff has already been dispersed or saved. I still have those rear calipers for instance RE: Purple turbo 240D - Purplecomputer - 08-28-2013 (08-28-2013, 01:56 PM)Simpler=Better Get some flare wrenches from harbor freight, both Us an dmetric. Total is like $25, they're totally worth every cent. The only catch is the crappy HF ones have a really big radius on the edge of the hex, and you need to grind them down "clean" yourself. Not a big deal just a heads up. Ive noticed that the HF tools are always a hit or miss. like my 11 isnt really an 11. its a little bigger then 11. so my 10 wont fit and my 12 is too big and my 11 is just a little bit bigger not allowing me to get a snug a proper fit on the bolt. (08-28-2013, 02:07 PM)JB3(08-28-2013, 01:15 PM)Purplecomputer thanks for the reassurance! well, for one, maybe that steel brake line and I has looking for some heater hoses and if you still had it some parts of the frame but you junked it. I dont live anywhere near a good pick n pull type yard so maybe you would want to go for me to get some parts off another car. (08-28-2013, 02:07 PM)JB3(08-28-2013, 01:15 PM)Purplecomputer thanks for the reassurance! well, for one, maybe that steel brake line and I has looking for some heater hoses and if you still had it some parts of the frame but you junked it. I dont live anywhere near a good pick n pull type yard so maybe you would want to go for me to get some parts off another car. RE: Purple turbo 240D - Simpler=Better - 08-28-2013 making your own lines from "cunifer" tubing is a priceless skill to have. cunifer is copper/nickle, so no rust and its easy to bend. seriously, flaring lines is a very important skill to have. a flare kit can be rented or bought fairly cheaply RE: Purple turbo 240D - Purplecomputer - 08-29-2013 (08-28-2013, 05:32 PM)Simpler=Better making your own lines from "cunifer" tubing is a priceless skill to have. cunifer is copper/nickle, so no rust and its easy to bend. seriously, flaring lines is a very important skill to have. a flare kit can be rented or bought fairly cheaply turns out I have a kit in my garage. ill give it a shot when I can afford to buy materials. where can I buy the adapters to screw it into the hole? RE: Purple turbo 240D - Simpler=Better - 08-29-2013 (08-29-2013, 10:35 AM)Purplecomputer(08-28-2013, 05:32 PM)Simpler=Better making your own lines from "cunifer" tubing is a priceless skill to have. cunifer is copper/nickle, so no rust and its easy to bend. seriously, flaring lines is a very important skill to have. a flare kit can be rented or bought fairly cheaply The threaded brake nuts? Any parts store will have them. Steel line is cheapest, followed by coated steel, followed by cunifer. Steel isn't terrible but it will rust out in a year or two with salt exposure. RE: Purple turbo 240D - waz - 08-29-2013 Unless your car is different than my '91. The nuts for the brake lines are M10x1.0 bubble flare nuts for 3/16"=4.75mm line. Pack of 5 from Autozone is $2.99 around here. http://www.autozone.com/autozone/accessories/AGS-5-pcs-3-16-in-tube-size-to-M10-1-0-thread-bubble-flare-European-steel-tube-nut/_/N-26hg?itemIdentifier=844779_0_0_ RE: Purple turbo 240D - Purplecomputer - 09-06-2013 okay! Got paid wednesday and bought parts that same day. I just got some new steel brake line (cunifer was to rich for my blood) The auto part had an already made line that I just put a few more bends to make it fit. I also covered it in underbody paint really sloppy job with that ![]() breaks are all done now and I installed a new power steering belt. took it for a test drive. the breaks need to be bled a little more but Its a PITA to bleed brakes by myself. might get that bleeding kit from HF sometime this weekend. im getting really lazy with pictures so heres this one. ![]() notice how its not going through that little holder tab welded in the car, well yeah I got lazy with that too. Not sure what the next phase of the project I should tackle. get all new exhaust or fix the front of the car (i.e. take off the fenders and everything and try to make it look nice) RE: Purple turbo 240D - Simpler=Better - 09-06-2013 Steel lines are on all my cars ![]() Rework it so it goes through that holder, or slit some fuel line and hose clamp it to the holder. Otherwise it will shake and eventually crack. If you're bleeding brakes by yourself, leave the bleeders open a little, attach vinyl tubing, and zip tie the vinyl so it's above the resarvoir. Fill the vinyl tubing and the res, let it sit for like 6 hours it *should* bleed itself. <-that procedure is thus far a rumor but I'd like you to test it out for me. ALSO, YOU FIXED THE BRAKES. WHEN YOU GOT TIRED YOU TOOK A BREAK. How does this sentance hurt your brain: "Yeah I fixed my rooter so now I have google again" See what I mean? RE: Purple turbo 240D - Purplecomputer - 09-06-2013 (09-06-2013, 03:16 PM)Simpler=Better ALSO, YOU FIXED THE BRAKES. WHEN YOU GOT TIRED YOU TOOK A BREAK. sorry, didn't realize the spelling mistake. let me fix that. you also spelled sentence wrong.... anyway, tried to remove the driver fender but Its stuck somewhere. I followed diesel giants guide. took my time but it seems to be stuck somewhere up top near the hood. figured out why Im having such a hard time removing the fender who ever painted it last time also put some stupid ass thick layer of spongy undercoat that also acts like a glue keeping. its almost impossible to remove this shit. Im going to have to replace the fender at this point. because its all bent up and dinged from the hammer cause I got pissed off. RE: Purple turbo 240D - 1911diesel - 09-06-2013 (09-06-2013, 04:12 PM)Purplecomputer(09-06-2013, 03:16 PM)Simpler=Better ALSO, YOU FIXED THE BRAKES. WHEN YOU GOT TIRED YOU TOOK A BREAK. been there done that, its fun while your doing it but after your all like "AWWWW DAMN!!!" ::face palm:: RE: Purple turbo 240D - Purplecomputer - 09-06-2013 Seriously, if I was just a tiny bit more patient I would have realised I can use a sanding tool to gently sand down the undercoat and remove it. I might just take it to a body shop at this point and have a "professional" do the work for me. Hell might even have it get a fresh coat of paint! RE: Purple turbo 240D - 1911diesel - 09-06-2013 yeah until you see how much they want to do it! lol i just see all that money flushing right down the drain with every extra set of hands that touches anything. not only that im hardly every impressed with what i paid for... at least when i do it myself and it looks/runs like crap i have no one to blame but myself. RE: Purple turbo 240D - Austincarnut - 09-06-2013 (09-06-2013, 08:02 PM)1911diesel yeah until you see how much they want to do it! lol i just see all that money flushing right down the drain with every extra set of hands that touches anything. not only that im hardly every impressed with what i paid for... at least when i do it myself and it looks/runs like crap i have no one to blame but myself. I agree, always fuck it all up yourself and always take full responsibility RE: Purple turbo 240D - Purplecomputer - 09-06-2013 You guys are right. regardless, I am going to replace the fender cause its all messed up from the paint and I fucked it up big time. I just realized I cant find these new online! OH SH** If anyone in has a PERFECT condition light ivory fender they want to send me or if they know of a good source for a replacement one let me know in the meantime. Im gonna try to fix this mess I made within the week. Ill take pictures of the doody I took on this car tomorrow morning. RE: Purple turbo 240D - willbhere4u - 09-06-2013 Early w123 fenders are glued on! They really suck to get off RE: Purple turbo 240D - Purplecomputer - 09-07-2013 (09-06-2013, 11:09 PM)willbhere4u Early w123 fenders are glued on! They really suck to get off really wish I knew that before hand. Could have saved myself some money and trouble. still, im on the lookout for that fender! anyone want to hit up and take a look for me when you guys go to the junk yard? |
