Strong transmission for G-Wagen??? - Printable Version
+--- Thread: Strong transmission for G-Wagen??? (/showthread.php?tid=1046)
Strong transmission for G-Wagen??? - gvp - 01-18-2010
Hello to everybody!!!I have a G-wagen and am planning to put the om606 with myna pump and a big turbo!!!
As will have much torque and as i want a manual gearbox,i decided to put one from Sprinter!!!
The code is:711.620 G32-5 and the gear ratio:
5.05:1
2.6:1
1.52:1
1:1
0.78:1
R4.76
I know that the vans have stronger transmissions than normally cars!!!
What do you believe???does it nice choise??
RE: Strong transmission for G-Wagen??? - winmutt - 01-20-2010
Interesting, does the sprinter transmission maatch up? I am suprised that is not a granny gear.
RE: Strong transmission for G-Wagen??? - ForcedInduction - 01-20-2010
5.05 to 2.6 is a granny gear if I'd ever call it one! Even the getrag 4-speed 240D only had a 4.23 1st.
RE: Strong transmission for G-Wagen??? - gvp - 01-20-2010
Sometimes for off-road use it's necessary the first short gear!!!Haw also an overdrive 5 gear....
All the transmissions of the trucks and commercial vans are stronger than normal cars....
Do you believe that will hold 350Hp???
RE: Strong transmission for G-Wagen??? - winmutt - 01-26-2010
(01-20-2010, 11:28 AM)ForcedInduction 5.05 to 2.6 is a granny gear if I'd ever call it one! Even the getrag 4-speed 240D only had a 4.23 1st.
It's wierd that 5th is an OD tho.. that was the only number I was really looking at.
RE: Strong transmission for G-Wagen??? - Syncro_G - 01-28-2010
(01-20-2010, 02:21 PM)gvp Sometimes for off-road use it's necessary the first short gear!!!Haw also an overdrive 5 gear....
gvp - that looks like a great gear ratio. the wide spread should suite the G-wagen nicely. Kind of like a mix between the 711.117 and the 711.116 transmissions.
Probably not great for racing on streets but good for off road.
-Christian
RE: Strong transmission for G-Wagen??? - gvp - 01-28-2010
Quote:gvp - that looks like a great gear ratio. the wide spread should suite the G-wagen nicely. Kind of like a mix between the 711.117 and the 711.116 transmissions.
-Christian
I am very interested for offroad use,but i like to go fast also at highway with the fifth overdrive!!!Wink
Hope that ll holds the torque!!!
RE: Strong transmission for G-Wagen??? - krashappy - 01-29-2010
Will you convert the ECU as well, the trans you describe is an electronic AT isn't it?
Which AT is currently under the hood ?
RE: Strong transmission for G-Wagen??? - gvp - 01-29-2010
(01-29-2010, 02:23 PM)krashappy Will you convert the ECU as well, the trans you describe is an electronic AT isn't it?
It's a manual trabsnission!!!
The car isn't ready yet,but ll have om606,myna pump and holset hx35...
RE: Strong transmission for G-Wagen??? - GREASY_BEAST - 01-31-2010
Sorry to throw a wrench into the mix. I don't know much about these transmissions, but I gather some people throw big american V8's in front of them... Maybe someone with some experience with these things will chime in.
http://en.wikipedia.org/wiki/Toyota_R_transmission
