airfilter system oil mist exhaust recirculation return pipe thing help!!!!!!!!!!! - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Maintenance (https://www.superturbodiesel.com/std/forumdisplay.php?fid=22) +--- Forum: General (https://www.superturbodiesel.com/std/forumdisplay.php?fid=4) +--- Thread: airfilter system oil mist exhaust recirculation return pipe thing help!!!!!!!!!!! (/showthread.php?tid=1085) |
airfilter system oil mist exhaust recirculation return pipe thing help!!!!!!!!!!! - turbo85 - 01-29-2010 i sprung a leak at the oil pan it was the pipe that comes from the oil return on the bottom of the air filter housing oil is bottle pressuring (blpowing out of dipstick du to unconstant and abnormally high oil psi what is the metal pipe what do i need to replace it and how does it connect where do i get parts RE: airfilter system oil mist exhaust recirculation return pipe thing help!!!!!!!!!!! - willbhere4u - 01-29-2010 If you take it out it just slides over a another pipe with an o ring you can replace the O rings |
