Personal Best Times for R&R - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: Open (https://www.superturbodiesel.com/std/forumdisplay.php?fid=13) +--- Thread: Personal Best Times for R&R (/showthread.php?tid=1176) |
Personal Best Times for R&R - winmutt - 02-27-2010 Post up your personal best times for R&R, if you can quote the shop labor estimate as well. Manual trans on 617, 5hrs today. RE: Personal Best Times for R&R - Rudolf_Diesel - 02-27-2010 Remove IP, adjust and replace 20 min. RE: Personal Best Times for R&R - ForcedInduction - 02-27-2010 Unplanned reinstallation of my transmission tailshaft in a parking lot, 2 hours and $30 (for borrowing a torque wrench and 30mm socket). RE: Personal Best Times for R&R - 300SD81 - 03-01-2010 tire rotation, <10 mins, with air wrench and 2 jacks RE: Personal Best Times for R&R - MB TECH - 03-01-2010 617 valve adjustment on 2 cars (one ended up doing twice) so 3 total jobs, 30-35 min (with starter button) seen an old timer at the last dealership I worked at do one car in less than 7 min (I thought the car was going to fire up he was hitting the start button so fast) |
