remove mechanical and install electric vacuum pump? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Maintenance (https://www.superturbodiesel.com/std/forumdisplay.php?fid=22) +--- Forum: General (https://www.superturbodiesel.com/std/forumdisplay.php?fid=4) +--- Thread: remove mechanical and install electric vacuum pump? (/showthread.php?tid=1238) |
remove mechanical and install electric vacuum pump? - JB3 - 03-24-2010 opinions? Electric pumps like off powerstrokes are thick on the ground, and cheaper than the OEM MB pump. example- http://cgi.ebay.com/ebaymotors/Ford-F250-F350-6-0L-SD-Diesel-Electric-Vacuum-Pump_W0QQitemZ220577715070QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item335b74d37e RE: remove mechanical and install electric vacuum pump? - ForcedInduction - 03-24-2010 No. They lack the volume needed to perform and they aren't made to run constantly. |
