Wastegate Hose Size for K26? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Wastegate Hose Size for K26? (/showthread.php?tid=1290) |
Wastegate Hose Size for K26? - capflya - 04-19-2010 I was going to order some new silicone hose for the wastegate because it's old and cracking but I don't know what size to get? I was going to order from siliconeintakes.com because it looks like they have what I need? They have 4, 6, 8, and 10mm hose on the site. Anybody know what size I need? If there is something else I should (or could) use let me know. The hose off of my T3 is too large of an ID/OD so I can't just borrow that. Thanks in advance. -David RE: Wastegate Hose Size for K26? - ForcedInduction - 04-19-2010 Should be 5 or 6mm. I used 1/4" fuel hose on mine. The T3 uses 8mm or 3/8". RE: Wastegate Hose Size for K26? - capflya - 04-20-2010 Awesome... I'll get some 1/4" hose for now... if/when I order some silicone parts I'll get the hose to... Thanks man! -David |
