W210 E300 - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: W210 E300 (/showthread.php?tid=1333) |
W210 E300 - big_mike - 04-30-2010 Doesn't seem to be much discussion about tuning the OM606 with its electronic fuel pump, is this because it is not possible without replacing with a mechanical unit? I really like the idea of a variable geometry turbo (totally fallen for the car in the three weeks I have had it) but whilst the mech side of things doesn't worry me too much I am in the dark on where to start with the electronic pump. Any advice appreciated, many thanks Mike RE: W210 E300 - jeemu - 05-01-2010 My friend has 605 electrical pump with 7mm elements. So it s possible tune RE: W210 E300 - meareweird - 05-05-2010 I believe aftermarket chips are available, my friend has one says it is much more fun. RE: W210 E300 - George3soccer - 05-06-2010 My friend dervtuning has went above and beyon in the 606 electronic pump. Check out his post. That's causing allot of discussion. |
