iol pan? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: iol pan? (/showthread.php?tid=1379) |
iol pan? - giezy - 05-20-2010 has any one or donea oil pan swap to make it a rear sump?i got a hold of a really nice 1986 fithavenue wiyh a bad motor but the are rea sump would like to through a 617 in it but the pan is the hold up RE: iol pan? - Biohazard - 05-20-2010 Havent done a pan swap, but my dad and I are (slowly) working on a 617 swap into his 64 Dart GT. We're having close to the same problem with oil pan location. Our plan is to just weld in a new crossmember then cut the old one out. Let us know if you find something that will work though. I believe there is another member working on something similar here: http://www.superturbodiesel.com/std/oil-pan-sump-options-for-om617s-t-1362.html Just remembered he's trying to move the sump a little, not move it to the other side. Hope it helps though. RE: iol pan? - ForcedInduction - 05-21-2010 It can't be done unless you use an external dry-sump style oil pump. |
