Dumb HX40 turbo question... - Printable Version
+--- Thread: Dumb HX40 turbo question... (/showthread.php?tid=1392)
Dumb HX40 turbo question... - E300TSC - 05-25-2010
OK, I have this HX40 but I have yet to determine what type of intake flange it has despite a throrugh searching of the internet. So, I'm trying to find out:
Do all HX40's have the same inlet flange?
If so, what type is it - T3, T4, T6?
Would it be easier to just fab up my own flange since I'm making the whole manifold any way?
Thanks!
RE: Dumb HX40 turbo question... - Alastair E - 05-25-2010
As far as I know, it is usually a T4 flange.....
Check the Holset site, which has the flange details on, although that page seems to take a while!
Measure up your current flange and compare...
These guys make complete manifolds for HX40 to 605 and 606, they also supply the 'blanks' (Flanges)
http://translate.google.com/translate?js=y&prev=_t&hl=en&ie=UTF-8&layout=1&eotf=1&u=http%3A%2F%2Fwww.kkdmotorsport.com%2Findex.php&sl=auto&tl=en for making up your own pipes..
RE: Dumb HX40 turbo question... - ForcedInduction - 05-25-2010
Should be a T3. Holset didn't go any bigger on them until the HX50 range was developed.
RE: Dumb HX40 turbo question... - dieseljunky - 04-23-2012
The HX40 came in both T3 and T4 flanges with many variations in comp wheel, turbine wheel, and exhaust housing sizes.
RE: Dumb HX40 turbo question... - dieselmerc - 04-24-2012
Hx40 has 3 sizes, t3, t4 and bigger t4 (89x70?) for size 19 on exhaust
RE: Dumb HX40 turbo question... - hansebanger77 - 05-01-2012
my smalest, first turbine was 16cm it was T3. now its 17cm housing T4 on my hx40.
RE: Dumb HX40 turbo question... - dieseljunky - 05-02-2012
I had a T4 housing that was a 19cm. I believe they came with a 20cm as well. A T3 16cm should be the smallest housing available for an HX40
