proper injector release pressure - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Maintenance (https://www.superturbodiesel.com/std/forumdisplay.php?fid=22) +--- Forum: General (https://www.superturbodiesel.com/std/forumdisplay.php?fid=4) +--- Thread: proper injector release pressure (/showthread.php?tid=1472) |
proper injector release pressure - rdirtycar - 07-01-2010 I'm about to balance my injectors and replace the tips with Monarks in my 617. What's a good pressure for the injectors to release at? My IP is an MW and original I think. RE: proper injector release pressure - GREASY_BEAST - 07-01-2010 135bar ~ 1960psi if your injectors are turbo injectors. (07-01-2010, 11:19 AM)rdirtycar I'm about to balance my injectors and replace the tips with Monarks in my 617. What's a good pressure for the injectors to release at? My IP is an MW and original I think. RE: proper injector release pressure - rdirtycar - 07-01-2010 Thanks! Is there a reason to ever deviate from this pop pressure? Like a modified pump? |
