lighten the flywheel? - Printable Version
+--- Thread: lighten the flywheel? (/showthread.php?tid=148)
lighten the flywheel? - lowriderdog37 - 03-24-2008
I am in the middle of my 4-speed conversion ('85 300CD). While I have it out, has anybody tried shaving a few pounds off the flywheel? Any input?
Re: lighten the flywheel? - bgkast - 03-24-2008
If you are using a flywheel from a 240D in your conversion then it is already a few pounds lighter than the flywheels that came on 617 engines. The lighter 240D flywheel works fine, but I don't think I would go any lighter.
Re: lighten the flywheel? - winmutt - 03-24-2008
Mine is from a 200D but I do not know if there is a difference between 200-240D.
You are aware that you will need to grind the crankshaft pilot or the pilot bearing on an 85 correct?
Re: lighten the flywheel? - ForcedInduction - 03-25-2008
winmutt You are aware that you will need to grind the crankshaft pilot or the pilot bearing on an 85 correct?
Ah, good point! I forgot about that. Yes, you'll need to machine the pilot bearing hole, buy a custom sized bearing or use a small bearing and machine a brass sleeve to fit around it.
Re: lighten the flywheel? - winmutt - 03-25-2008
I took my bearing to a grinder.
Re: lighten the flywheel? - lowriderdog37 - 03-26-2008
I didn't get a bearing with the trans I bought. Do you happen to know what size it is off hand? Or is it something I can just pick up at my local mechanics shop?
I didn't know anything about that...thanks for the heads up!
Re: lighten the flywheel? - winmutt - 03-27-2008
Its a common bearing, I know that much. Check out autohauseaz or fastlane for the part, look up a 240d manual.
I don't that its been mentioned in your threads here or else where but you will need to adjust the length of the shifting rods as well.
Re: lighten the flywheel? - bgkast - 03-27-2008
lowriderdog37 I didn't get a bearing with the trans I bought. Do you happen to know what size it is off hand? Or is it something I can just pick up at my local mechanics shop?
I got mine from NAPA.
