MW pump on euro 300d non turbo?? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Maintenance (https://www.superturbodiesel.com/std/forumdisplay.php?fid=22) +--- Forum: General (https://www.superturbodiesel.com/std/forumdisplay.php?fid=4) +--- Thread: MW pump on euro 300d non turbo?? (/showthread.php?tid=1495) |
MW pump on euro 300d non turbo?? - kmaser - 07-14-2010 I was under the impression that all of the N/A om617, especially the euro cars were the M pumps. I have a parts car and removed the pump just assuming it was an M pump but have found that it has MW in the tag number. Is this correct? RE: MW pump on euro 300d non turbo?? - bmwpowere36m3 - 07-14-2010 M pumps are only on European Non-Turbo 617. MW pumps are on ALL Turbo 617 and US Non-Turbo 617. RE: MW pump on euro 300d non turbo?? - kmaser - 07-14-2010 I guess maybe this pump was changed at some point then, as this 300D was imported from Italy...I even have the original bill of sale. RE: MW pump on euro 300d non turbo?? - mike-81-240d - 07-15-2010 So If I put the '83 turbo injection pump I have on my non turbo '77 engine I wouldn't see a change? RE: MW pump on euro 300d non turbo?? - bmwpowere36m3 - 07-15-2010 Turbo MW pumps are different than Non-Turbo MW pumps, in the ALDA and fueling in general. RE: MW pump on euro 300d non turbo?? - mike-81-240d - 07-16-2010 Maybe I'll give it a go and see what happens whether it be worse performance, better performance, or non stop smoking... RE: MW pump on euro 300d non turbo?? - ForcedInduction - 07-16-2010 (07-15-2010, 11:16 AM)mike-81-240d So If I put the '83 turbo injection pump I have on my non turbo '77 engine I wouldn't see a change? Right. There is no boost to burn additional fuel or actuate the ALDA so you wouldn't get any more fueling than a non-turbo engine usually gets. RE: MW pump on euro 300d non turbo?? - Fernando BR - 07-19-2010 Hi Force induction , how you increase diesel delivery in your 240D without ALDA? thanks RE: MW pump on euro 300d non turbo?? - ForcedInduction - 07-19-2010 Same as the turbo model, adjust/remove the rack limiter. |
