96 E300 om606 Diesel IP question - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Maintenance (https://www.superturbodiesel.com/std/forumdisplay.php?fid=22) +--- Forum: General (https://www.superturbodiesel.com/std/forumdisplay.php?fid=4) +--- Thread: 96 E300 om606 Diesel IP question (/showthread.php?tid=1496) |
96 E300 om606 Diesel IP question - capflya - 07-14-2010 My friend has a N/A om606 E300 (from 1996). His injection pump went out and he found a replacement from a turbo om606. Will the turbo IP work in the N/A car? I don't know very much about the newer cars. I looked around a bit but I can't find what I'm looking for. If anyone knows if the turbo IP will work in the N/A car let me know. He needs a new IP but doesn't want to spend the money on it unless it will work (obviously ) Thanks RE: 96 E300 om606 Diesel IP question - ForcedInduction - 07-14-2010 No. The injection elements are a different size which will piss off the ECM and set a CEL. RE: 96 E300 om606 Diesel IP question - capflya - 07-15-2010 Ok... Thanks for the quick response... In that case does anyone have a NA om606 IP? Posting a wanted thread now... |
