Re: Shocks replacement - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Suspension (https://www.superturbodiesel.com/std/forumdisplay.php?fid=5) +--- Thread: Re: Shocks replacement (/showthread.php?tid=154) |
Re: Shocks replacement - MTUPower - 03-19-2008 what is the stock length of w123 front/rear springs- and how do the vogtland's compare? I've just bought a set from omegabenz- for my wagon... :? what pads would you suggest? Edited to read springs Re: Shocks replacement - winmutt - 03-20-2008 Vogtlands= springs not shocks. That is a good question about the height on the shocks tho. Bilstein does not make sports for this car, however I wonder if the other manufacturers have different heights. Re: Shocks replacement - MTUPower - 03-20-2008 winmutt Vogtlands= springs not shocks. That is a good question about the height on the shocks tho. Bilstein does not make sports for this car, however I wonder if the other manufacturers have different heights.Does anyone have the Vsprings and what nub pads would you recommend for front and rear? Re: Shocks replacement - winmutt - 03-21-2008 3 rear 1 front. Has worked well for the two turbos I did. I cant remember what the non turbo was, I think he had 2/1. |
