Turbo on a 617 N/A - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Maintenance (https://www.superturbodiesel.com/std/forumdisplay.php?fid=22) +--- Forum: General (https://www.superturbodiesel.com/std/forumdisplay.php?fid=4) +--- Thread: Turbo on a 617 N/A (/showthread.php?tid=1553) |
Turbo on a 617 N/A - Fernando BR - 07-29-2010 I know 617A is a diferent animal , with piston lubrification, special valves, etc...The question is that here government rules are very complex about engine changes. Other hand i do not want to change datacard engine . My idea is basicly instal a garret or kkk and stay with M RSF pump only increasing about 20 or 30% IP delivery. That will give me the little extra powe i need without high EGRs troubles as at high speeds and high offroad rpms moisture is going to be poor . Troubles? RE: Turbo on a 617 N/A - ForcedInduction - 07-30-2010 If they have a problem with changing engines, why wouldn't they have a problem with adding a turbo too? Anyways... A little power (10-20%) won't significantly hurt the lifespan. The turbo engines only have 40% more power and if you've read the SAE paper you know what troubles MB had just to get that. RE: Turbo on a 617 N/A - Fernando BR - 07-30-2010 What they want to see is if the engine has correct number stamped on the block . They really dont know if its a turbo engine or not. Thanks |
