Locked Diff - Printable Version
+--- Thread: Locked Diff (/showthread.php?tid=1563)
Locked Diff - garage - 08-01-2010
Does anyone know if any of the G-wagens had locking diffs?
I was thinking it might be possible, if the Gwagens did have a locking diff, to maybe adapt..if not just get an idea to lock up a w123.
RE: Locked Diff - ForcedInduction - 08-01-2010
Technical data 290GD - W461
Стр. 1 из 2 03.12.2007 20:36
Technical Data 290GD - W461 long wheelbase
290 GD short wheelbase 290 GD van 290 GD
Pickup
290 GD Chassis 3120mm 290 GD Chassis 3400mm
Engine Specifications & Performance
Cylinders / arrangement 5/bank, 2 valves per cylinder
Displacement (bore x stroke)
[cm³ (mm)] 2874 (89,0 x 92,4)
Compression ratio
[:1] 22
Rated output
[kW(PS)/rpm] 70 (95) / 4000
Rated torque
[Nm/rpm] 192 / 2300
Generator / battery output 14 V/55 A / 12 V/72 Ah
Fuel injection mechanical
Fuel consumption city / 90 km/h / 120 km/h
With standard transmission
[l/100 km] 13,1 / 9,8 / 15,0
With automatic transmission
[l/100 km] -
Acceleration 0-100 km/h
[s] 23
Top track speed
[km/h] 132
Drivetrain
Gear ratios 1st -5th / reverse gear
5-speed Standard
[i=]
3,856 / 2,183 / 1,376 / 1,0 / 0,799
/ 3,705-
4-speed automatic
[i=] n/a
5-speed automatic
[i=] n/a
Final drive 5-speed man./ 4-speed auto./ 5-speed auto.
[i=] 4,857 / - / -
Chassis
Front axle
Rigid axles located by two trailing links and one transverse link, torsionbar stabiliser,
differential lock
Rear axle
Rigid axles located by two trailing links and one transverse link, differential lock
Brakes
diskbrakes front, drumbrakes rear
Steering MB power-assisted steering
Wheels 6 J x 16
Tires 205 R 16
Dimensions & Weight
Wheelbase
[mm] 2850
Track front / rear
[mm] 1425
length / width / height
[mm] 4580 / 1700 / 1945
Turning circle
[m] 13,0
Curb weight + payload = total weight
[kg] 2105 + 795 = 2900
Towing capacity unbraked / braked
[kg] 750 / 3500
Technical data 290GD - W461 http://www.g4rce.net/technical-data/w461-290gd-lwb.html
Стр. 2 из 2 03.12.2007 20:36
Trunk capacity
[l] 480 / 2250
Tank capacity / reserve
[l] 96
RE: Locked Diff - garage - 08-02-2010
Well ive been scouring the world wide web trying to find some photos of the rear diff/axle, but none to my luck yet.
I will try to post them when i come across them.
Is there potential for using this setup for our cars, if anyone knows?
Well i guess the G-wagen have a solid axle, so im not sure its adaptable.
RE: Locked Diff - ForcedInduction - 08-03-2010
I'd be into adapting an air locker, detroit locker or MB's hydraulic ASD.
http://www.offroaders.com/tech/arb-air-locker.htm
http://www.eaton.com/EatonCom/ProductsServices/PerformanceProducts/Products/Differentials/DetroitLocker/
RE: Locked Diff - Captain America - 08-03-2010
http://www.eaton.com/EatonCom/ProductsServices/PerformanceProducts/Products/Differentials/DetroitTruetrac/index.htm
That is what is going into my GMC Sprint
RE: Locked Diff - garage - 08-03-2010
So i think i should take the benz to a 4x4 shop and have somone look at it in person to see how easy it would be to make work on these diffs.
Looks much to complicated for me to even try haha
RE: Locked Diff - Captain America - 08-04-2010
Diffs are not hard to work on, they just require some tools that you usually don't have laying around... you got to get the pinion depth right and stuff...
