Blowby - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Maintenance (https://www.superturbodiesel.com/std/forumdisplay.php?fid=22) +--- Forum: General (https://www.superturbodiesel.com/std/forumdisplay.php?fid=4) +--- Thread: Blowby (/showthread.php?tid=1775) |
Blowby - Leprechaunliam - 09-27-2010 Hey guys, I'm pretty new to the forum and wanted to get some opinions. I'm looking to buy an '87 300SDL that has a greasecar kit in it. I've looked the car over pretty well and it seems that there are little mechanical concerns. I am concerned with one aspect though, and that is blowby. After driving for about 40 mins (mostly testing the turbo, the guy claimed it had just been rebuilt) I pulled over to check things out. Opened up the crankcase and noticed oil was sputtering and a little smoky. Didn't get too good of a look because I didn't want oil sputtering all over the block. With the cap just resting on the opening, it sat pretty nicely without bouncing around. The car has about 220k on it, but I was wondering if that seemed like a concern to some of you older and wiser guys? I know blowby is in all engines, but do those symptoms seem reasonable for 40 mins of hard driving and the mileage? Do you think I should be concerned? RE: Blowby - winmutt - 09-27-2010 Was the engine running when you pulled over? RE: Blowby - Leprechaunliam - 09-27-2010 (09-27-2010, 08:55 AM)winmutt Was the engine running when you pulled over? yes it was RE: Blowby - winmutt - 09-27-2010 The tea kettle test will only tell you if your engine is about dead, its useful for noobs who dont know what a diesel is supposed to run like. The only real test is a proper compression test. Chances are its ok. Whats the head stamping? RE: Blowby - ForcedInduction - 09-27-2010 (09-27-2010, 07:05 AM)Leprechaunliam that has a greasecar kit in it. Reason enough to skip it. RE: Blowby - Leprechaunliam - 09-28-2010 (09-27-2010, 06:40 PM)ForcedInduction(09-27-2010, 07:05 AM)Leprechaunliam that has a greasecar kit in it. haha I take it you don't like wvo? I'm not sure what the head stamp was; I know that car had problems with the head cracking though; is that why you're asking? RE: Blowby - Olivier - 10-07-2010 Sputtering? How bad? You might have some ring gumming Veg does that sometimes. Water injection seems to cure it. THere was a guy in another forum with a E300TD who had exessive blowby, oil stick poping out, rough engine and all, he misted some water in the manifold while driving and it cured it. Grenwrench here has a water injection in his car and he's happy with. Olivier RE: Blowby - ForcedInduction - 10-08-2010 Water injection is a poor band-aid. BioDiesel is the cure. |
