Need 606 Injection pump diagrams/ inside pictures - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Maintenance (https://www.superturbodiesel.com/std/forumdisplay.php?fid=22) +--- Forum: General (https://www.superturbodiesel.com/std/forumdisplay.php?fid=4) +--- Thread: Need 606 Injection pump diagrams/ inside pictures (/showthread.php?tid=1916) |
Need 606 Injection pump diagrams/ inside pictures - Olivier - 10-31-2010 Hello, I might pull my pump out the car but I need to know what I am looking for, like I don't know what/ where the plungers are? Why do I need to be carefull at the "large washer" position ( the one under the element?) as it looked round to me from a previous diagram. I need to know how it work inside for me to be able to disasemble it and put it back together in the right order after a good clean. Thank you . Olivier RE: Need 606 Injection pump diagrams/ inside pictures - ForcedInduction - 10-31-2010 (10-31-2010, 05:36 AM)Olivier I need to know how it work inside for me to be able to disasemble it and put it back together in the right order after a good clean. You can't. Only a Diesel injection shop can do it, a test bench is required. RE: Need 606 Injection pump diagrams/ inside pictures - Olivier - 10-31-2010 Oh... You bring in some bad news... I am still sure something as been clogged in the pump and wanted to open it to "clean" it better then Moly purge or other cleaning that didn't do anything so far. I was going to look at the DV first, I changed the Orings/ springs and copper washers not long ago then I know how to get there, but I don't understand why the bottom need to be positionnned properly ( I didn't even took the element out as too worry something goes wrong there). Cheers. Olivier |
