hvac problem and wastegate oil? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: Open (https://www.superturbodiesel.com/std/forumdisplay.php?fid=13) +--- Thread: hvac problem and wastegate oil? (/showthread.php?tid=2096) |
hvac problem and wastegate oil? - larsalan - 12-27-2010 Was on the interstate today coming back from xmas vacation. Everything was going great but, I had 2 issues. One the heat started to blow luke warm air then onto colder. I pulled off and as I slowed on the ramp the heat blasted back. It went out again later and didn't come back till I got home, shut her off and back on again. Does that point to any clear issue? Also, this will be my third time doing this trip. The first time I lost about a quart of oil. The second a bit less. And this time it seemed like a lot more. I posted once about oil all in my wastegate and I think this is where the majority of it's going. This third trip I was up on the wastegate for the majority of the time where the other trips I was boosting lower. Don't know why, maybe the colder air? Does that sound reasonable? That the oil is sneaking into the wastegate as blowby vapor. thanks RE: hvac problem and wastegate oil? - ForcedInduction - 12-27-2010 Oil in the wastegate is normal from the CCV recirculating to the intake. Cold water could be the circulation pump stopping and restricting flow. It usually just needs a new o-ring, corrosion removal and a drop of oil on the bearings. RE: hvac problem and wastegate oil? - larsalan - 12-28-2010 yeah, I remember you saying oil in the wastegate was normal. AT 8.65 a quart I can't afford to be loosing the stuff so quickly. I'm saying the wastegate is set at like 10psi and this trip I was pegged on that 10psi @ 65+ mph. Where before I was generating 8-9 psi and it seams that less oil was lost. Maybe I can have an air/oil separator on the line leading to the wastegate? |
