ALDA doesnt kick in when cold - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Maintenance (https://www.superturbodiesel.com/std/forumdisplay.php?fid=22) +--- Forum: General (https://www.superturbodiesel.com/std/forumdisplay.php?fid=4) +--- Thread: ALDA doesnt kick in when cold (/showthread.php?tid=2251) |
ALDA doesnt kick in when cold - winmutt - 02-09-2011 My ALDA takes forever to kick in when cold. Like 10-15min of driving. This is on the 87. Have a hard time believing its sticking... But I guess it could be? Ideas? RE: ALDA doesnt kick in when cold - 300D50 - 02-09-2011 Pop it off, clean it with something rubber-seal friendly. Likely has EGR goop in it that takes a bit to warm up and de-sludgify. Or, your shaft seal is possibly leaky? RE: ALDA doesnt kick in when cold - winmutt - 02-10-2011 Oh that might be an easy fix. I will get a can of brake cleaner and see what comes out of the ALDA. I cant get it off without taking manifold or IP off. RE: ALDA doesnt kick in when cold - 300D50 - 02-10-2011 Be careful with the brake parts cleaner, you don't want to eat the oring or shaft seal. RE: ALDA doesnt kick in when cold - winmutt - 02-10-2011 Maybe wd40 then? Although I if the capsule was full of gunk I really wouldnt have this problem... RE: ALDA doesnt kick in when cold - 300D50 - 02-10-2011 WD or PB are my thoughts, diesel also would work. RE: ALDA doesnt kick in when cold - totaldisaster - 02-10-2011 Its not the ALDA. Clean / bypass the switchover valves or the intake grommet. RE: ALDA doesnt kick in when cold - winmutt - 02-11-2011 Its not the switch over valve, bypassed it still happens. Intake grommet? You mean the banjo? This was cleaned when I purchased the car. RE: ALDA doesnt kick in when cold - totaldisaster - 02-11-2011 It just doesn't make sense that an ALDA would be 'finnicky'.... if they fail, they fail. Could you have a boost leak? A sticky wastegate / or a dirty valve could be the cause. When it warms up, it seals better? RE: ALDA doesnt kick in when cold - winmutt - 02-11-2011 (02-11-2011, 12:25 PM)totaldisaster It just doesn't make sense that an ALDA would be 'finnicky'.... if they fail, they fail. This could be very true. I did just hook up the wastegate hose for the first time in probably a long time (bought the car this way about a year ago). RE: ALDA doesnt kick in when cold - casioqv - 02-11-2011 (02-11-2011, 02:13 PM)winmutt This could be very true. I did just hook up the wastegate hose for the first time in probably a long time (bought the car this way about a year ago). You were running with no wastegate? The "overboost protection system" is supposed to disable ALDA enrichment if the boost is too high, although on my car (if the wastegate is adjusted too high or disconnected) this kicks back and forth causing "bucking" rather than just a steady decrease in power. Still, you could have some sort of electrical issue where those solenoid valves aren't allowing the ALDA to see boost until it's warmed up. If you T a boost gauge right before the ALDA you can see if boost is getting to it or not. RE: ALDA doesnt kick in when cold - winmutt - 02-11-2011 (02-11-2011, 02:28 PM)casioqv(02-11-2011, 02:13 PM)winmutt This could be very true. I did just hook up the wastegate hose for the first time in probably a long time (bought the car this way about a year ago). When I first got the car, the overboost solenoid was plugged. I replaced it and had more power. Then after I put in the manual transmission I started getting this wierd cyclic up down power thing at WOT, at the time I thought it was filters. Turns out it was the overboost system cycling in and out which I figured out after I saw the WG hose just laying there. As I have bypassed the overboost solenoid, it certainly cant be that causing the issue. I am not even sure its the ALDA specifically. For all I know it could be the ELR. All I know is that I don't have fuel enrichment for 10-15minutes after start when its really cold outside. It is directly connected to temperature, when warmer or the engine is warm the time is shortened. RE: ALDA doesnt kick in when cold - casioqv - 02-11-2011 (02-11-2011, 02:42 PM)winmutt I am not even sure its the ALDA specifically. For all I know it could be the ELR. All I know is that I don't have fuel enrichment for 10-15minutes after start when its really cold outside. It is directly connected to temperature, when warmer or the engine is warm the time is shortened. Interesting... My theory is that it's *somehow* related to the thermostatic system which is supposed to make the automatic transmission shift smoother when cold. It has a temp switch on the engine block, and a solenoid valve which I believe is supposed to keep the "blue flying saucer" from seeing boost (and therefore firming up shifts in response to power) until the engine is warmed up. Could somehow during your manual swap, this have gotten connected in a weird way so that this system is bleeding off the boost signal to the ALDA until the thermostatic switch kicks in? Quick test- just unplug the temp switch (by the engine thermostat, above the alternator) and see if you get ALDA enrichment immediately on a cold start. RE: ALDA doesnt kick in when cold - aaa - 02-11-2011 I still think you should remove it. It's not as hard as you think, "only" 15 minutes of wrangling to get it out after getting it loose iirc. On top of that, usually when this happens to me the car is extremely slow. As in, way less than an NA diesel slow. That makes me doubt that it is not-seeing-boost related. Although I wonder what happens if vacuum somehow gets in. Maybe just leave the tube hanging unconnected and see what happens? RE: ALDA doesnt kick in when cold - winmutt - 02-11-2011 It is physically impossible for me to remove my ALDA. without removing the intake/IP, I spent well over 15minutes after I got te ALDA loose trying to fish it out. There was some talk on BW and basically if the pump was put in at a certain angle (timing still right) .... It is a straight run from the manifold to the ALDA. I do believe that it is probably sticking. However even this evening, I got in the car temp still read just under 80* c after getting home from work and it still took several minutes for it to kick in. |
