fuelpump om606 300td - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: fuelpump om606 300td (/showthread.php?tid=2362) |
fuelpump om606 300td - johan84 - 03-08-2011 hello i'm new at this forum i have read a lot but now made my account i'm from holland i have a daily driver w123 petrol on lpg i thinking of buying a diesel much more fun high torque and higher mpg but i have read a lot about the om606 24v tuning i have a question about the fuelpump when the engine is tuned to run with a bigger turbo and higher pressure is a myna pump always needed or can also the element just be changed from 5mm to 7mm? can the injectors be standard als when going to 400hp? what is the best to use a ecu controled fuelpump or the older fuelpump full mechanical ? and are the electronic's on the market to reprogram the new need fuel delivery? i now a lot of question i have collected them ![]() RE: fuelpump om606 300td - johan84 - 03-09-2011 nobody? did i do somehing wrong? did i overlooked something ![]() RE: fuelpump om606 300td - aaa - 03-09-2011 I think someone mentioned this recently. It certainly is possible to upgrade the electronic pump, it's just that it's not done. Presumably because mechanical is easier to adjust. There is no aftermarket electronics. You will have to figure out the electronics yourself or have someone figure it out. That is most likely the reason people don't use the electronic pump. RE: fuelpump om606 300td - johan84 - 03-10-2011 oke so a fuelpump of a om603 is used instead i will have a look at the electronics and will use the seach engine better ![]() |
