Factory MB SLS block off plate for Hydropneumatic pump with harware - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: FS / WTB / Buying guides (https://www.superturbodiesel.com/std/forumdisplay.php?fid=8) +--- Thread: Factory MB SLS block off plate for Hydropneumatic pump with harware (/showthread.php?tid=2446) |
Factory MB SLS block off plate for Hydropneumatic pump with harware - totaldisaster - 03-27-2011 This is a square, reinforced plate that allows you to block off the SLS bore on W123 617 wagon heads and and certain gas engines as found on the 560SEL etc.. Pics on request. $25 shipped (or less if the coating is not perfect) RE: Factory MB SLS block off plate for Hydropneumatic pump with harware - ForcedInduction - 03-28-2011 There isn't a factory plate. The "factory" SLS-delete is a different head casting. RE: Factory MB SLS block off plate for Hydropneumatic pump with harware - totaldisaster - 03-28-2011 pic (unclean) RE: Factory MB SLS block off plate for Hydropneumatic pump with harware - ForcedInduction - 03-28-2011 Part number? RE: Factory MB SLS block off plate for Hydropneumatic pump with harware - totaldisaster - 03-28-2011 Sorry, I don't have EPC... nor do I really care. This does not have an MB logo on it.... but there must be some parts that don't have numbers. There were a few gas models where the SLS was optional and rather than making an entirely different head casting, they put this on. I have only seen it a few times, so I grabbed it.... I have a spare wagon head now and thought it would be good to hold on to. |
