will these tires fit? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: Open (https://www.superturbodiesel.com/std/forumdisplay.php?fid=13) +--- Thread: will these tires fit? (/showthread.php?tid=2466) |
will these tires fit? - larsalan - 04-02-2011 http://www.performanceplustire.com/products/tires/?searchType=searchBySize§ionWidth=215&aspectRatio=75&rimDiameter=14&submit=Submit&manufacturerID%5B%5D=94&manufacturerID%5B%5D=228&manufacturerID%5B%5D=28&manufacturerID%5B%5D=83&manufacturerID%5B%5D=355&manufacturerID%5B%5D=325&manufacturerID%5B%5D=27 will a 215x75x14 fit on a bundt? I am about to run out of rubber and wanted to order these asap. How can I tell if the width of these is compatible? I was at walmart today to find out that a crap load of steel was popping out of one tire and it was about to blow and another is not far behind. All a result of that stupid control arm bushing. RE: will these tires fit? - garage - 04-02-2011 I do not know from experiance, but i think they would. The biggest ive had on a bundt was i think 205/70-14. I dont remember Captain Americas tire size on his red w123, but he has some gnarly offroad tires on there.. RE: will these tires fit? - larsalan - 04-02-2011 Well they are narrower right? at 75 instead of 70. Will I be able to have a shop mount them? I am thinking so but, I would hate to be stuck with some tires that I can't use. RE: will these tires fit? - garage - 04-02-2011 (04-02-2011, 02:27 PM)larsalan Well they are narrower right? at 75 instead of 70. Will I be able to have a shop mount them? I am thinking so but, I would hate to be stuck with some tires that I can't use. Yeah i belive 75 is narrower. What is your current tire size? RE: will these tires fit? - larsalan - 04-02-2011 195/70/14 I just wonder will this tire mount on the rim. Can only afford 2 for the rear right now. Can't even really afford that but, I guess I'll have to. That new tire size is 2 in larger diameter so 1 in bigger radius I don't see how that could be a problem. Just that I don't understand width of the rim and tires. RE: will these tires fit? - garage - 04-02-2011 Yeah, im in the same boat with ya, im not crystal clear on all that either. I would say i THINK so, but i would get some more opinions. RE: will these tires fit? - larsalan - 04-02-2011 from what I can gather they will fit on the rim http://www.peachparts.com/shopforum/archive/index.php/t-223331.html http://home.seebz.com/redirect.php?tid=32373&goto=lastpost RE: will these tires fit? - larsalan - 04-09-2011 Yes, they will. I got them today. |
