Dyno filmclip 6 mm 250 TD - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Dyno filmclip 6 mm 250 TD (/showthread.php?tid=2528) |
Dyno filmclip 6 mm 250 TD - dieselmeken - 04-19-2011 The engine with the 6 mm pump here http://www.maxxtuning.se/kundbilar/effektmatning-orginal-ecu/232whp-mercedes-w123--jim/ RE: Dyno filmclip 6 mm 250 TD - Captain America - 04-19-2011 That thing sounds mean! RE: Dyno filmclip 6 mm 250 TD - willbhere4u - 04-19-2011 witch engine is that? RE: Dyno filmclip 6 mm 250 TD - George3soccer - 04-19-2011 om605 if I remember correctly. RE: Dyno filmclip 6 mm 250 TD - dieselmeken - 04-19-2011 Yepp, 605.960. 110kw/150 hp stock RE: Dyno filmclip 6 mm 250 TD - mantahead - 04-20-2011 (04-19-2011, 11:28 PM)dieselmeken Yepp, 605.960. 110kw/150 hp stockhi, how does it rev so high on standard ecu? wayne RE: Dyno filmclip 6 mm 250 TD - dieselmeken - 04-20-2011 (04-20-2011, 01:40 PM)mantahead(04-19-2011, 11:28 PM)dieselmeken Yepp, 605.960. 110kw/150 hp stockhi, how does it rev so high on standard ecu? No ECU mecanical pump in this one RE: Dyno filmclip 6 mm 250 TD - mantahead - 04-20-2011 (04-20-2011, 01:48 PM)dieselmekenhi, i was wondering why it said original ecu on the clip, i thought someone had done a conversion to electronic.(04-20-2011, 01:40 PM)mantahead(04-19-2011, 11:28 PM)dieselmeken Yepp, 605.960. 110kw/150 hp stockhi, how does it rev so high on standard ecu? Do you know anyone can make w202 c250td rev high with ecu? RE: Dyno filmclip 6 mm 250 TD - willbhere4u - 04-20-2011 I'm curious why they converted an om605 in to a w123? I have seen om603 and om606 in a w123 before I'm not judging I think it's a very nice set up and wish I had something similar in my 240d RE: Dyno filmclip 6 mm 250 TD - dieselmeken - 04-21-2011 (04-20-2011, 03:32 PM)willbhere4u I'm curious why they converted an om605 in to a w123? In Sweden, cars older than 30 years are taxfree ,No roadtax no nothing. Just fuel, so it´s a economic decision. Wery popular to put in newer engines in old chassies and save money. The reason it´a 605 in this one, no answer, but I think he had the engine. RE: Dyno filmclip 6 mm 250 TD - MTUPower - 04-21-2011 (04-19-2011, 12:48 AM)dieselmeken The engine with the 6 mm pump hereCould never be a daily driver here in the USA with that smoke output at idle. What turbo is used? RE: Dyno filmclip 6 mm 250 TD - Captain America - 04-22-2011 (04-21-2011, 07:52 PM)MTUPower(04-19-2011, 12:48 AM)dieselmeken The engine with the 6 mm pump hereCould never be a daily driver here in the USA with that smoke output at idle. What turbo is used? Why not? Believe it or not California doesn't care about smoke! RE: Dyno filmclip 6 mm 250 TD - Riverstick - 04-25-2011 I see the condom falling off the tow hitch @1.10.....the sign of good performancce for sure! |
