fs springs - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: FS / WTB / Buying guides (https://www.superturbodiesel.com/std/forumdisplay.php?fid=8) +--- Thread: fs springs (/showthread.php?tid=2561) |
fs springs - larsalan - 04-25-2011 Ok, got the front springs out. Dunno how to get the rear ones out, the spring compressor I borrowed couldn't fit in there. But maybe I can get them out when I chop through the frame ![]() Also, I wonder how in the h#ll you're supposed to work that compressor. Even after I compressed the springs I still needed to take apart the upper control arm to get the mf out of there. oh and a power steering pump too. RE: fs springs - Captain America - 04-26-2011 Ummmm, I just use a big crowbar..... Like this! http://www.sears.com/shc/s/p_10153_12605_00943277000P?prdNo=21 Makes for some excitment RE: fs springs - mike-81-240d - 04-26-2011 How much shipped to 98033? Don't really wanna chop the stockers. Fronts only. RE: fs springs - larsalan - 04-26-2011 They are about 30lbs and 18in long. Would you look into the shipping and we could figure a price? There's some rust on there but would brush off with a flap disc. I'll try and get the backs off too. ![]() RE: fs springs - mike-81-240d - 04-26-2011 Damn... Not short enough for a flate rate box. RE: fs springs - larsalan - 04-26-2011 usps about 50 ups about 40 fedex about 35 That's all from their online estimators. Wanna pay 50 on top of the shipping? RE: fs springs - mike-81-240d - 04-26-2011 holy shit... Lemme check my H&R sources first ![]() RE: fs springs - winmutt - 04-27-2011 Did you use the plate compressor? You want to rotate the plates all the way to the top and bottom. RE: fs springs - larsalan - 04-27-2011 Plate compressor? I just borrowed a strut spring compressor from the autopart store ![]() How can I get the back springs out? The bolts on that one I borrowed were way too long to fit in the area. RE: fs springs - Biohazard - 04-27-2011 I've pulled the rear springs several times now. The easy way is remove the shocks, remove swaybar links, loosen the subframe mounting bolts about 1/2 inch. Put a jack under the rear diff and then unbolt the rear diff mount. Lower the rear end down and the springs just fall right out! RE: fs springs - larsalan - 04-27-2011 Ok, I'll try that. If it ever stops raining and I can get a day off work. RE: fs springs - larsalan - 05-09-2011 Now have all the springs if anyone wants a whole set. $60 +shipping |
