Cylinder head flow bench numbers - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Cylinder head flow bench numbers (/showthread.php?tid=2584) |
Cylinder head flow bench numbers - zx670 - 05-02-2011 I have been searching for a while now for some numbers to compare and have not found anything so figured Id post what I got in case anyone else is looking, I put a 617 head on a superflow bench @28" to see what I got out of it, unfortunately due to circumstances I was unable to do it when it was totally stock so these numbers are after a slight port job and a 5 angle. Lift Intake Exhaust relationship .100" 63.4 52.2 82% .200" 114.4 89.8 78% .300" 141.5 119 84% .400" 160.4 142 89% after 400" the valve shrouding was so great there was no real gains, RE: Cylinder head flow bench numbers - Alastair E - 05-04-2011 Hmm--Interesting! Thanks for sharing.... Guess this was for the 'Turbo 617.951/2' engine? |
