W201 OM601 -->> OM606 N/A - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: W201 OM601 -->> OM606 N/A (/showthread.php?tid=2629) |
W201 OM601 -->> OM606 N/A - EDH_Performance - 05-17-2011 Hi guys, I have an 93 mod MB 190D, and I have plans for swapping my 2.0D OM601 N/A for a 93 mod OM606 N/A, and mye questions are regarding this: 1. Will the OM601 flywheel fit the OM606 (The 606 has org autotrans) 2. Will the OM601 engine mounts fit the OM606 block? (They look the same) 3. Will the stock 4-speed transmition fit the OM606 Best regards Daniel RE: W201 OM601 -->> OM606 N/A - aaa - 05-17-2011 yes. yes. yes. RE: W201 OM601 -->> OM606 N/A - EDH_Performance - 05-17-2011 Best news ![]() The flywheel was my biggest concern... RE: W201 OM601 -->> OM606 N/A - aaa - 05-17-2011 I'd wonder about whether the clutch can handle the power. It's a small 8" disc. RE: W201 OM601 -->> OM606 N/A - EDH_Performance - 05-17-2011 (05-17-2011, 04:08 PM)aaa I'd wonder about whether the clutch can handle the power. It's a small 8" disc. I see, the only way to test it is to try ![]() Do you know how big the stock 606 clutc is? And is the fly wheel heavier? RE: W201 OM601 -->> OM606 N/A - aaa - 05-17-2011 The stock is probably a dual mass. 240mm would be my guess. The trend for the single mass seemed to be for flywheels to be lighter on the six-cylinders. Look for what ]winmutt does with his om603 turbo, which has a little more hp. He's trying an 8.5" right now. RE: W201 OM601 -->> OM606 N/A - erling66 - 05-18-2011 (05-17-2011, 04:13 PM)EDH_Performance(05-17-2011, 04:08 PM)aaa I'd wonder about whether the clutch can handle the power. It's a small 8" disc. my 606 n/a w124 had a dual mass FW with 9 inch clutch. There are photos in a transmission tread. |
