What is this noise : OM603? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: What is this noise : OM603? (/showthread.php?tid=2643) |
What is this noise : OM603? - TheDon - 05-22-2011 http://www.youtube.com/watch?v=GhtwTgejOgQ my 300D is making a weird noise from the belts. I'm not sure what it is from. The noise is located on the exhaust side and increases with revs. No idea if its the tensioner or the alternator or a loose belt RE: What is this noise : OM603? - tomnik - 05-22-2011 check the rubber bearing (eyes) of the tensioner by using a screw driver pushing on. I can not hear it clearly with the hood closed but the tensioner bearing is clattering noise. Tom RE: What is this noise : OM603? - winmutt - 05-26-2011 Check the tensioner. Use a hammer handle and push down on it and see if it goes away. My tensioner spring broke one day out of no where. |
