Has anyone fitted a W201 steering box into a W123? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Suspension (https://www.superturbodiesel.com/std/forumdisplay.php?fid=5) +--- Thread: Has anyone fitted a W201 steering box into a W123? (/showthread.php?tid=2661) |
Has anyone fitted a W201 steering box into a W123? - fha772 - 05-29-2011 Hi all, As the title says really, since I've been thinking about converting my 280E track car project to rack and pinion steering. A friend has got in touch to say he has a 190E 2.5-16v, steering box, that I can have. Which is roughly 2.5 turns lock-to-lock. This sounds like the simpler option to me, just just swap 1 steering box for the other, so has anyone done this swap? Thanks Frank. RE: Has anyone fitted a W201 steering box into a W123? - RonB - 06-10-2011 fha772 Hi all,The guys at Black smoke racing in Finland used a Jag ( i think) rack and pinon to give more steering . http://youtu.be/YlwTxw-027o how to build a drift car with a mercedes Estate id='30107' dateline='1306670313 RE: Has anyone fitted a W201 steering box into a W123? - Kozuka - 06-10-2011 16v's don't have rack and pinion, its just a short ratio steering box. I have both a W123 300TD & a W201 16v, if you were to ask me I don't think it will be a bolt on affair. Do you have a welder and fabrication skills? |
