1979 300SD Turbo Diesel ... rear CLUNK when turning - Printable Version
+--- Thread: 1979 300SD Turbo Diesel ... rear CLUNK when turning (/showthread.php?tid=2680)
1979 300SD Turbo Diesel ... rear CLUNK when turning - 300SD_KY - 06-04-2011
2 days ago, i ran over something in the driveway ... and I heard a "creak".
This morning when driving around a bend/curve or turning at any speed, I hear a loud CLUNK CLUNK CLUNK ... sounds like the rear wheels would be coming off. But they are solid.
Nothing "hanging" or loose when I do a visual inspection.
Any help what went wrong much appreciated.
Christian
1979 Mercedes Benze 300SD Turbo Diesel
110,000 miles
Silver Exterior
Black Leather Interior
RE: 1979 300SD Turbo Diesel ... rear CLUNK when turning - willbhere4u - 06-04-2011
sounds like a bad rear CV Axel
RE: 1979 300SD Turbo Diesel ... rear CLUNK when turning - dieselboy - 06-04-2011
check the sway bar end links. I broke one and it would rub the axle on a turn. That and the cv joints
RE: 1979 300SD Turbo Diesel ... rear CLUNK when turning - lpumb3 - 01-23-2013
my rims would rub on the front springs evry time i would jack up the car for any length of time . just barley and it was the weights hitting the spring.
RE: 1979 300SD Turbo Diesel ... rear CLUNK when turning - cutaresku - 01-24-2013
Broken spring I would guess.
RE: 1979 300SD Turbo Diesel ... rear CLUNK when turning - lpumb3 - 01-26-2013
nah it was lift , casing a rub on the top of the rim . it would contact above the bumpstop in the rear .when ever i get a rub thats not obvious i put a bunch of masking tape in the wells . this was with a set of 18x9 rears mandrus et was 42? fronts 18x8 et 37? never had probs in the front with these. the front spring contact was with a set of vw rim 17x7.5 et 32 i believe and just the edge of on of the wieghts that was on a bend . but the spring would settle past it after a day or 2. may car would sit on stand for at least a day at a time .springs scare the crap outta you when your banging a uturn. BIONG!BIONG! BIONG!
rear needs more rear sway bar and lower 2front 1 back minimum . or spacers and just those
