recently noticed that my spare om617 IP has some sort of electronic device attached - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: recently noticed that my spare om617 IP has some sort of electronic device attached (/showthread.php?tid=2682) |
recently noticed that my spare om617 IP has some sort of electronic device attached - mr_manny - 06-05-2011 is this for emissions? ![]() thanks, manny did a quick search, looks like this is some sort of rack sensor found in 85 specific IPs... RE: recently noticed that my spare om617 IP has some sort of electronic device attached - totaldisaster - 06-05-2011 A benign electromagnetic sensor for emissions. Does not effect a thing. Also found on many '84s. I capped mine off by filling the cover plate with JBweld and slapping directly onto the pump housing. It makes pump timing much easier due to increased access to that third bolt between the engine and IP. RE: recently noticed that my spare om617 IP has some sort of electronic device attached - mr_manny - 06-05-2011 (06-05-2011, 01:09 PM)totaldisaster A benign electromagnetic sensor for emissions. Does not effect a thing. good info...thanks |
