looking for engine performance info - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: looking for engine performance info (/showthread.php?tid=278) |
looking for engine performance info - dlang - 03-14-2009 I put togeather a performance calculator to let me play 'what if' games for engine, transmission, gear, and tire changes for my off-road trucks, it's grown a wee bit beyond what I initially planned for, and I am having people ask me to add information for the mercedes diesels to it the calculator is available at http://scout.lang.hm/scout/nph-performance6.cgi in a quick look around here I found one torque graph in the thread at http://www.superturbodiesel.com/std/dyno-results-t-187.html I don't understand why the upgraded engine has a much narrower rpm range. are there any other graphs or charts that show the performance of the various engines? (ideally a torque graph/chart, but I can calculate from a horsepower chart/graph) I'd also like to add the transmissions if someone could point me somewhere that gives their specs. RE: looking for engine performance info - winmutt - 03-14-2009 Those are two different dyno runs (and different dynos if I remember correctly). RE: looking for engine performance info - ForcedInduction - 03-15-2009 (03-14-2009, 06:26 PM)dlang I don't understand why the upgraded engine has a much narrower rpm range. Two different runs a few months apart done by different operators, same dyno. The second guy wasn't used to a diesel that could revv past 3500rpm. EDIT: I noticed on your calculator that you listed MB a 6 cylinder, it should be 5. RE: looking for engine performance info - dlang - 03-15-2009 (03-15-2009, 02:56 AM)ForcedInduction(03-14-2009, 06:26 PM)dlang I don't understand why the upgraded engine has a much narrower rpm range. I changed the 6 to 5 anyone have any better numbers for me to put in there? RE: looking for engine performance info - ForcedInduction - 03-15-2009 I'll be putting my stock 300D on the dyno in a week or two for a baseline run. |
