w123 manual transmission question - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: w123 manual transmission question (/showthread.php?tid=2855) |
w123 manual transmission question - TheDon - 08-12-2011 Got my spare 4 speed for my 240D to swap in. The only difference is the reverse shift lever is upside down compared to mine. See the bottom arm. Can they be removed and flipped or will that not work? I couldn't find the shifter rods that were supposed to go with the transmission. I'm replacing my current transmission because 1st gear is not working at all. I need to double check. I have an '82 and loping at the sticky on the manuals the curtsy transmission in my car is the aluminum body 4 speed. Nevermind. I just went out and looked. Shift levers are oriented the same. The only difference is the last 4 or 5 digits of the transmission number. RE: w123 manual transmission question - winmutt - 08-18-2011 IIRC there is a allen bolt in that hole in the arm, can you confirm? RE: w123 manual transmission question - JB3 - 08-23-2011 (08-18-2011, 07:14 AM)winmutt IIRC there is a allen bolt in that hole in the arm, can you confirm? Its a 6mm allen |
