Coolant pipe with euro manifold 603 - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Coolant pipe with euro manifold 603 (/showthread.php?tid=2859) |
Coolant pipe with euro manifold 603 - winmutt - 08-14-2011 Anyone have a fix for this? Is there a 606 part or 126/140 pipe that works? RE: Coolant pipe with euro manifold 603 - aaa - 08-14-2011 The 126 pipe won't work very well.There was a thread on PP a while back that didn't seem to yield much... here. RE: Coolant pipe with euro manifold 603 - iheartboost - 08-14-2011 ive always been a fan of flexible lines. so maybe thats an option for you? i know when i get on my way for the power aspect of my car there will be no custom bent oil or coolant lines. ill just use braided or something similar. RE: Coolant pipe with euro manifold 603 - winmutt - 08-14-2011 (08-14-2011, 07:47 AM)aaa The 126 pipe won't work very well.There was a thread on PP a while back that didn't seem to yield much... here. I'll talk to rusty and see if he can send me some EPC pics... RE: Coolant pipe with euro manifold 603 - jonbobshinigin - 08-16-2011 I believe that there is a pipe off of an om602 that you actually need. I will see if I can find out the information I likely stored somewhere and forget I did it. RE: Coolant pipe with euro manifold 603 - 300D50 - 08-16-2011 Is it something you could make out of a strip of hobby-shop brass/aluminum sheet, some pipe fittings, and time? RE: Coolant pipe with euro manifold 603 - winmutt - 08-16-2011 Its the 602 tube. The problem is the bracket keeps the tube compression fitted into the tstat housing. There is a oring on the end to keep it from leaking. Im sure I can find a 602 tube somewhere. If by some miracle I have everything else done by this weekend I'll consider just using what I have and clamping it off until I can get the right part. |
