need help from the experienced - Printable Version
+--- Thread: need help from the experienced (/showthread.php?tid=289)
need help from the experienced - ALLDiesel - 03-23-2009
i have a 1987 300SDL. Car has a vibration at high speeds so i took the driveshaft out. The universal wasnt perfect and had a couple tight spots. Went to order one and was told they don't sell it. Got looking at it and noticed no clips holding it in. I was told i need to buy the entire driveshaft for $600!!! Anybody had this problem?
RE: need help from the experienced - ForcedInduction - 03-23-2009
The u-joint never moves, it will always have "tight spots" because it wears in just one spot. Unless there is significant play in the joint it shouldn't need to be changed.
Replace the driveshaft support and I bet your vibrations will go away.
RE: need help from the experienced - kamel - 03-24-2009
Had the same experience on mine. New center bearing and support made it all go away.
