Springs and sway bars for 78 300cd - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Suspension (https://www.superturbodiesel.com/std/forumdisplay.php?fid=5) +--- Thread: Springs and sway bars for 78 300cd (/showthread.php?tid=291) |
Springs and sway bars for 78 300cd - crunky - 03-24-2009 So, I have a 78 300CD and I am looking to do some minor suspension work to it. From what I have read, it looks like I might be able to use progressive springs off of a Gas coupe. Does anyone know how these compare to my stock springs? Any difference in ride height? It also looks like I can find bigger sway bars out of a TD wagon, does it matter what years? And, where can I find these? I have tried ebay with no luck as of yet. If its of any help, my goal here is mainly to eliminate roll while keeping a nice ride. I don't want to turn it into a sports car, I just want it to feel a little less boaty. RE: Springs and sway bars for 78 300cd - winmutt - 03-24-2009 Springs, same ride height, better handling. Swaybar, turbo wagon 81 and up. Junkyards are you best bet or hitting up the other forums for people parting. Wagon springs up front with a link chopped off will probably do wonders. RE: Springs and sway bars for 78 300cd - crunky - 03-25-2009 Awesome, exactly what I was looking for.. Thank you. Now, when you are talking about wagon springs, what exactly is different about them compared to coupe or sedan springs? RE: Springs and sway bars for 78 300cd - winmutt - 03-25-2009 Stiffer, if you have the FSM they have a complete chart of the 8 or so different springs that the W123 came in. If you are going to cut coils the best way is to start with a stiffer spring. RE: Springs and sway bars for 78 300cd - Ghaniba - 06-24-2009 Would this same info work for an '81 CD? -Ghan RE: Springs and sway bars for 78 300cd - GREASY_BEAST - 06-26-2009 I have 2 sets of wagon springs for sale. RE: Springs and sway bars for 78 300cd - charmalu - 09-04-2009 There is a 79 280CE @ PNP. Installing the rear springs in my 85 300D will improve the handling? There is also a 85 wagon Iam thinking about removing the front sway bar also. since I installed the 240D 4-speed, and later used the 240D front springs to lower the front end. going into a sharp curves on a mountain road, the handling is a little mushy. most driving the ride is great. Installing the wagon sway bar should take out the mush and stiffen it up, right? Charlie RE: Springs and sway bars for 78 300cd - SurfRodder - 09-04-2009 (06-24-2009, 10:49 AM)Ghaniba Would this same info work for an '81 CD? it should... AFAIK all the front susp. is interchangeable... RE: Springs and sway bars for 78 300cd - winmutt - 09-04-2009 (09-04-2009, 12:49 AM)charmalu There is a 79 280CE @ PNP. Installing the rear springs in my 85 300D willOnly if they are progressive. (09-04-2009, 12:49 AM)charmalu There is also a 85 wagon Iam thinking about removing the front sway bar also.It will help control the roll. RE: Springs and sway bars for 78 300cd - DeliveryValve - 09-05-2009 (09-04-2009, 12:49 AM)charmalu .... Charlie, Get it! And get the rear lights, fuel sender and what ever you can get from the SLS also. People always looking for those... RE: Springs and sway bars for 78 300cd - charmalu - 09-05-2009 Reading in the FSM, removing the sway bar looks easy enough. HMMMM, now that I said that, it will probably be on the high end of the PITA scale Do the progressive springs have a different look to them? are they easy to identify? Charlie RE: Springs and sway bars for 78 300cd - DeliveryValve - 09-05-2009 (09-05-2009, 02:15 AM)charmalu ... Progressive springs have tighter coil spacing in the middle of the spring while near the top and bottom ends the coil spacing is larger. I have yet to see them on a w123. RE: Springs and sway bars for 78 300cd - charmalu - 09-05-2009 Thanks Richard. save me from unnessary work. I was looking at that 79 Gasser, and they looked evenly spaced. thought the way I red above the Gassers had them. Charlie RE: Springs and sway bars for 78 300cd - winmutt - 09-06-2009 (09-05-2009, 02:19 AM)DeliveryValve I have yet to see them on a w123. My euro had them. They we stock for the 280?CE. Rear only. |
