240d om617 swap - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Maintenance (https://www.superturbodiesel.com/std/forumdisplay.php?fid=22) +--- Forum: General (https://www.superturbodiesel.com/std/forumdisplay.php?fid=4) +--- Thread: 240d om617 swap (/showthread.php?tid=2916) |
240d om617 swap - carlitosgy6 - 08-29-2011 hi, i need to know if its possible to swap an om616 from a 240d with a 617 without changing the transmission RE: 240d om617 swap - aaa - 08-30-2011 Sure. You'll change other things instead though. Is this manual or automatic? RE: 240d om617 swap - winmutt - 08-30-2011 Perhaps you can clarify what is swapping into what? |
