Noob question on 602 engine. - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Noob question on 602 engine. (/showthread.php?tid=301) |
Noob question on 602 engine. - Achtung - 04-02-2009 Hi Guys, I´m new at this forum, but I think this is the right place for my question. I´m thinking of putting a diesel engine in a boat. And I think the engine is a 602. It´s from a MB 190d 2.5 10valve. I´m not a big MB fan, but I like this engine. It seems to be a light diesel engine with big possibility to get big power. So now to my question, what shall I do with this engine to reach my hp output goal. To get the boat to the speed I want I will need around 200-250hp. What shall I do?? Ofcourse I will need a big turbo, but do I need to modify the pump and put in larger pistons in the pump?? /Anton RE: Noob question on 602 engine. - fragatadas - 04-02-2009 Is the engine 602n.a or 602turbo? What sort of speed are you looking for? What the hull shape and weight? In any of the cases this engine will need a belt driven sea water pump, seawater/coolant radiator, seawater/oil cooler, seawater/air intercooler and a cooled exhaust manifold if you run it over 3000rpm . My extensive experience with boats at sea, tells me that reliability is more important than performance! Over water you can't get out and push...... If you are looking for a light diesel in a boat get a Volvo Penta KAMD32 or Yanmar. RE: Noob question on 602 engine. - ForcedInduction - 04-02-2009 A 602 might not be the best for marine performance. I'd look for a 603 to get 200-250hp so that HP/L is lower and the engine will be more reliable. The 190D isn't turbo except in 1987 and the non-turbo engines don't have the piston cooling, reinforcements or cam profile for a turbo. |
