124 brake upgrade - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Brakes (https://www.superturbodiesel.com/std/forumdisplay.php?fid=11) +--- Thread: 124 brake upgrade (/showthread.php?tid=324) |
124 brake upgrade - oel_brenner - 04-19-2009 just finished up brake upgrade on the 124 swapped in brakes from a E420 in the front upgraded to 294 x 25 rotor and the four piston calipers from the stock 284 x 22 rotor and the stock caliper in the rear upgraded to the vented 278 x 24 rotor with the dual piston caliper from the solid 258 x 9 rotor and single piston caliper. also installed teflon/stainless hoses. while its not quite the E500 brakes, the new braking performance is absolutely breathtaking.. old rear subframe / new rear subframe: ![]() brake lines: ![]() RE: 124 brake upgrade - winmutt - 04-22-2009 Where did you get the hoses? $? RE: 124 brake upgrade - oel_brenner - 04-22-2009 (04-22-2009, 05:25 PM)winmutt Where did you get the hoses? $? had them made up at the local hydraulic fab joint http://www.amazonhose.com/ $80 for all four he made them up while I waited.. no shipping ![]() basically the same parts as what this guys sells http://www.wrxtra.com/catalog/index.php?cPath=32 RE: 124 brake upgrade - squirrelmaster - 11-03-2009 Hi my name is andy I Would like to know if the whole e430 subframe bolts on to a w124 300d my car has a 5speed from a 190 2.3 16 valve, i am drooling over those giant rotors, and Is that diff from the 430 have Lsd? Whats the ratio, if possable i will put a subframe, brakes and diff from one in my car. Thanks please get back to me. (04-19-2009, 09:27 PM)oel_brenner just finished up brake upgrade on the 124 RE: 124 brake upgrade - oel_brenner - 11-07-2009 (11-03-2009, 06:44 PM)squirrelmaster Hi my name is andy I Would like to know if the whole e430 subframe bolts on to a w124 300d my car has a 5speed from a 190 2.3 16 valve, i am drooling over those giant rotors, and Is that diff from the 430 have Lsd? Whats the ratio, if possable i will put a subframe, brakes and diff from one in my car. Thanks please get back to me. you may want to check out this thread: http://www.superturbodiesel.com/std/124-rear-subframe-upgrade-t-325.html |
