How far should I tear into it? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: How far should I tear into it? (/showthread.php?tid=3252) |
How far should I tear into it? - aka rover - 01-10-2012 1983 om617 turbo 200K runs good a little bit of a rough idle but started last week at -2 deg without being plugged in, so good compression I would think. I have the motor out and on a stand and was wondering how far I shoud go into it? It is a oily mess and i have cleaned it up and was going to replace all oil gaskets and seals. Should I remove head and replace gasket, or just run it there isnt any signs of leaks. Should I reseal main pan or just the metal small one? The IP pump is dry and not leaky but the hand pump sprays back at me when I pump it, so a replace or rebuild is in order. Turbo is stock but would like to upgrade it and add fuel to the motor to gain a few HP while im at this point. I have a KKK26 I took off my 930 to upgrade it? its the 3ldz from a 79. Not sure it will work or not. Should I replace timming chain at this point and guides. Any thoughts would be great Cheers Ed RE: How far should I tear into it? - Captain America - 01-10-2012 Valve adjustment, check timing chain. Replace easy seals if you are going to play with the IP, do it on the stand, will be much easier RE: How far should I tear into it? - TexasSuperDecel - 01-10-2012 I have 700,000 miles on the original head gasket in my OM617. If there are no noticable problems with it on a stand. I'd run it. I would do the following if I were to purchase a used OM617 or had it on a stand before install for ease of access especially if in a different chassis. Valve cover gasket OEM $ 5.23 ( Hand primer pump OEM $15.06 Intake manifold gasket OEM $ 14.20 Turbo mounting gasket kit OEM $ 33.72 Oil filter housing to engine block gasket OEM $ 3.14 Oil pan gasket OEM $ 13.09 Timing tensioner spring OEM $ 4.72 Timing tensioner gasket OEM $ 0.91 Oil filter OEM $ 8.54 Canister type fuel filter OEM (Bosch) $ 7.83 Inline fuel filter depending on setup. Belts. Upper/Lower radiator hoses. Thermostat. RE: How far should I tear into it? - willbhere4u - 01-10-2012 I'd also do the front main seal and rear if it leaking! RE: How far should I tear into it? - dude99 - 01-12-2012 I'd do the front and rear main seals even if they weren't leaking. There a pain in the ass to do with the engine in and there cheap. Do them no forget about them later. |
