Weird intake manifold - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Weird intake manifold (/showthread.php?tid=3271) |
Weird intake manifold - Simpler=Better - 01-13-2012 What do you guys think of this intake manifold? Supposedly from a '78 300D Could it complete with a W115 intake? RE: Weird intake manifold - larsalan - 01-13-2012 I have one like that. And I saw another one at the pick n pull. Still havent tried to install it due to $, time, weather. I hope the snail will fit between those runners. I pulled mine out of 79-80 na 300d, I think not the sd just d. Does that seem right? RE: Weird intake manifold - Simpler=Better - 01-13-2012 Sounds right to me! I ordered bot the intake and exhaust manifolds. $150 for "long-runners", I couldn't build them for that cheap. RE: Weird intake manifold - larsalan - 01-13-2012 Man, I got my intake one for like $11. Didnt take the exhaust cause it was not gonna be set for a turbo and my exhaust. Need to plump a boost sensor line into that place where the rubber 90 is at. RE: Weird intake manifold - Simpler=Better - 01-13-2012 Oh I've got plans for it. And a HE351VE RE: Weird intake manifold - willbhere4u - 01-13-2012 here is another even cooler manifold http://www.superturbodiesel.com/std/showthread.php?tid=241 That will clear the stock turbo manifold RE: Weird intake manifold - Simpler=Better - 01-13-2012 I couldn't find a W115 intake so I went with this guy. If a w115 pops up later I'll definitely grab it ![]() (01-13-2012, 01:01 PM)willbhere4u here is another even cooler manifold http://www.superturbodiesel.com/std/showthread.php?tid=241 RE: Weird intake manifold - duderino - 03-04-2012 i got first manifold u guys posted, w123 na manifold off of 77-79 300d. Any ideas on how to get it to clear ANY turbo? Any one know how to modify an exhaust manifold to lower the t3 flange? RE: Weird intake manifold - Simpler=Better - 03-05-2012 An offset flange can angle the turbo downward, shouldn't be too hard to mill. Just watch your clearances on the fender wall. I'm planning on routing the turbo up near the alternator in my build RE: Weird intake manifold - serverman777 - 03-05-2012 (01-13-2012, 10:16 AM)larsalan I have one like that. And I saw another one at the pick n pull. Still havent tried to install it due to $, time, weather. You got one? If so we are putting it on my car..... |
